Need Assistance with GNS3 - OSPF Configuration Issue
Ruby Grace
While working with GNS3 and configuring OSPF.I've been trying to set up a network topology where multiple routers communicate using OSPF. I've gone through the configuration steps carefully, double-checking my subnetting and ensuring that the interfaces are correctly assigned to their respective areas. However, when I run the simulation, it seems like the routers aren't forming any OSPF adjacencies.
Login to RapidFS Portal
 payroll online management
All-point network
Rapid  Pay Card
balaji.bandi
Post the Router config here, as Long as peer reachable and configuration correct (if there is no ACL ) - OSPF is straight forward to establish peer relation.
check video for good reference :
https://www.youtube.com/watch?v=Iib20MF8y-c
BB
M02@rt37
Hello @Ruby Grace,
Please share router's config for more assistance.
Best regards
Joseph W. Doherty
Areas, plural?
If so, there are additional "rules" for using those.
As the others have already requested, posting router configs, even for just two neighbors, may help us identify the problem(s).
