Cisco ISR 1900 unable to recover
roycemathew
Hi All,
I have a new ISR 1900 router on which i accidently deleted the default username and password and now i am unable to get in to router console.
Also i am unable to break in to Rommon mode as well. Can any one help
paolo bevilacqua
Check you are sending break, or replace USB serial adapter. Some fail to send break.
Thanks for the response
issue is resolved, the process for this is clearly explained in Cisco.
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml
hope this helps someone getting in to the same issue.
