Cisco ISR 3925 Redundancy setup
NInja Black
 I am looking to setup up redundancy for our Cisco ISR 3925 routers. Please share a link to an example.
Also does the router redundancy work same as an ASA active/standby setup? i.e. all the config automatically syncs to the standby unit and when failover happens the standby takes the active IPs.
Alan Ng'ethe
Level 3
Level 3
Did you get a solution to this? I am in a somewhat similar situation.
If so, please share.
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
n-kirillov
Hi Ninja!
Yes, you may use IPSEC HA with this platform
https://www.cisco.com/en/US/technologies/tk583/tk372/technologies_white_paper0900aecd80278edf.html
Good luck
CCIE, Irkutsk, Russia
Sincerely from Nik
