Cisco ISR 4321 port forward not working
j947561905
I have recently gotten into Cisco and I am struggling to open a few ports on my Cisco ISR 4321 router.
Port forward of 8920 does not forward however 3389 does work. Any ideas what is wrong?
Currently I have tried the commands:
ip nat inside source static tcp 192.168.16.240 8920 zzz.zzz.zzz.zzz 8920 extendable
But I have also tried:
ip nat inside source static tcp 192.168.16.240 8920 interface Dailer1 8920
and
ip nat inside source static tcp 192.168.16.240 8920 interface GigabitEthernet 0/0/1 8920
interface GigabitEthernet0/0/0
ip address 192.168.16.254 255.255.255.0
ip nat inside
negotiation auto
spanning-tree portfast disable
interface GigabitEthernet0/0/1
description Primary_
no ip address
ip mtu 1492
ip nat outside
ip tcp adjust-mss 1412
media-type rj45
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 1
vrf forwarding Mgmt-intf
no ip address
negotiation auto
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp mtu adaptive
ppp authentication chap pap callin
ppp chap hostname zzzzzz@zzzzz
ppp chap password 0 zzzzzzzzz
ppp pap sent-username zzzz@zzz password 0 zzz
ppp ipcp dns request
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 100 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.16.0 255.255.255.0 Dialer1
ip access-list extended 100
30 permit ip 192.168.16.0 0.0.0.255 any
ip access-list extended 197
dialer-list 1 protocol ip permit
route-map track-primary-if permit 1
match ip address 197
set interface Dialer1
TJ-20933766
You say that 3389/tcp is working just fine? I'm assuming that you only did it for testing and then removed the configuration?
Can you verify that 8920/tcp is allowed on whatever that host on the inside is? Sometimes the host firewall is the culprit and not the actual configuration of the router. You can verify that the translation is working by performing the following command:
show ip nat statistics
Look for increasing numbers on the "Hits".
Hello, than you for helping. Yes TCP 3389 does work when I open the port.
I have run that command. Below is the output
r1#show ip nat statistics
Total active translations: 576 (2 static, 574 dynamic; 576 extended)
Outside interfaces:
GigabitEthernet0/0/1, Dialer1, Virtual-Access2
Inside interfaces:
Hits: 93773923 Misses: 501476
Expired translations: 500889
Dynamic mappings:
-- Inside Source
[Id: 3] access-list 100 interface Dialer1 refcount 577
nat-limit statistics:
max entry: max allowed 0, used 0, missed 0
In-to-out drops: 0 Out-to-in drops: 131955
Pool stats drop: 0 Mapping stats drop: 0
Port block alloc fail: 0
IP alias add fail: 0
Limit entry add fail: 0
Outside global interfaces count: 2
I check the hits bit and the number is going up.
you could try and block the port from being used for overloading:
ip nat settings interface-overload block port tcp 8920
Hello
Is the nat device open for tcp 8920?
Try removing the static route pointing your lan subnet via it wan interface and also remove that specific host from the global NAT
no ip route 192.168.16.0 255.255.255.0 Dialer1
10 deny tcp host 192.168.16.240 any eq 8920
Kind Regards
Paul
