Cisco ISR 4331 command Help Help!
ohforce55
I'm trying to copy the config from 3825 to ISR 4331.
But some commands aren't taking in 4331 so I did some research..
1. ip cef
 - it is enabled by default?
2. nbar command
- ip nbar port-map custom-02 tcp 3389
- ip nbar port-map custom-01 tcp 6129
nbar is there but not port-map.... How should I configure on 4331?
I was able to configure ' ip nbar protocol-discovery' though.
3.
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
- these 2 commands don't work
4. ip flow
- I had to configure flexible NetFlow record, export, and monitor.
This part is fine but can I put 2 destinations under export?
Because on 3825, these two lines are configured.
ip flow-export destination 172.31.69.50 9995
ip flow-export destination 172.31.69.217 9996
By the way, Is it also normal that I can't ping 172.31.69.50 or .217 on the router?
How can I change that two commands to 4331?
flow exporter export
description OPNET Netflow Collector
source Loopback199
transport udp 9996
5. scheduler allocate 20000 1000 , and
 ntp update-calendar
These 2 don't work on 4331... Please help
6. interface g0/0/0
 speed ...
I can't also config speed under interface.
I will very appreciate if you can help.
Thank you in advance!
Yadira
I had the same problem with the speed, the commands that worked for me were:
int g0/0/0
media-type rj45
speed 100
no negotiation auto
with fiber you can't change the speed.
You need 2 separate exporter maps with flex netflow cant be dOne under 1
scheduler doesnt exist in these devices same with update calender there IOS commands not IOS-XE
port-map should still work i just tested it , its hidden
(config)#ip nbar port-map telnet tcp 23
(config)#do sh ver | i 433
cisco ISR4331/K9 (1RU) processor with 1648589K/6147K bytes of memory.
(config)#
NBAR Port-map Cli to be hidden for future deprecation
CSCug39332
Description
Symptom:
ip nbar port-map will be hidden
Conditions:
The clis is hidden for future deprecation. The usage of the command will remain the same.
Workaround:
The cli is hidden but still usable
Customer Visible
The resolution of this defect introduces a change in behavior, or additional functionality, over previous releases
Was the description about this Bug Helpful?
(0)
Details
