02-12-2024 11:21 AM
I have an ISR 4331. I have to restart often because users can't load pages.
The show int g0/0/1 command on the LAN interface configured with virtual interfaces indicate massive packet drops.
02-12-2024 11:29 AM
Share the config if you can
MHM
02-12-2024 11:55 AM
02-12-2024 12:01 PM
More than one inside toward one public IP'
Check show ip nat statistics
When traffic start drop check if there is drop in-to-out
I think your NAT is exhaust abd you need more public ip's
MHM
02-12-2024 01:52 PM
Thanks, I will try that and update you on the results
