Cisco ISR 4461 bidirectional traffic capacity
Does Cisco ISR 4461 supports encrypted bidirectional traffic up to 10G?
Thanks in advance.
7 Replies 7
it does, as far as I recall. You do need the boost (for unlimited bandwidth) and HSEC l(to remove the 170Mbps encrypyed traffic limit) icenses, though.
Thanks a lot.
I got the HSEC license for this ISR.
What could be the boost in this case? How to find out the SKU for it?
Thanks in advance.
I got FL-4460-BOOST-K9 SKU for it. Is it correct? Is it sufficient for the bidirectional traffic up to 10G?
How much capacity increased due to 1 FL-4460-BOOST-K9 license?
Thanks in advance.
while adding this item with above mentioned SKU, I received following warnings.
-FL-XXX-BOOST-K9 is incompatible with SDWAN Image (CE100009)
-IOS Technology Package Licenses,Unified Communications,,DVD for ISRWAAS SW Version,Energy Wise MaIagement,PVDM4 DSP’s,mSATA Solid State Drive,Serial Cable ASYNC,Akamai Connect,VADSL Firmware Options,PWR-44XX-POE-AC and FL-44XX-PERF is incompatible with is incompatible with SDWAN Image (CE100009)
How can I proceed here?
Thanks in advance.
there are hardware/software dependencies, check the white paper below:
https://www.cisco.com/c/en/us/solutions/collateral/enterprise-networks/sd-wan/white_paper-c11-741071.html
I agree with Joseph, 'over 7Gbps' is rather vague, it means 'more than 7Gbps, but does not give an upper limit...
BTW, according to Georg's reference the 4461, with boost license, can provide over 7 Gbps.  If you're need 10G, bidirectional, then you'll need up to 20 Gbps.  I would suspect the 4461 will fall short.  Further, the ISR 4K series often seem to struggle obtaining their performance license throughput when doing IPSec.
Just found https://blog.router-switch.com/2019/01/the-new-cisco-isr-4461-faq/ which has the 4461 of supporting up to 7 Gbps for crypto.  Also that document notes it can provide (non-crypto) of 10Gbps, but without services.
The 4461's 7Gbps crypto performance is also noted in this: https://fastreroute.com/cisco-routers-performance/.
