Cisco Packet Tracer Network Help
Bassicaly, I have a network that looks like this:
The only issue i'm currently having is communicating between devices in router1 to the other devices. They can communicate within router1 just fine but can't go outside.
I've tried a bunch of static routes but I cannot get a single one to work. Currently the one I have is this:
Router0:
Router1:
I also have DHCP on Router1 if that matters.
I posted the packet tracer file here below as well.
All help is appreciated
on the left router, add:
Router(config)#ip route 31.208.78.0 255.255.255.192 31.208.45.13
Attached the revised, working file.
Thanks a lot man, that makes more sense
the topology is a bit 'weird' in the sense that you have two routers connected to the same LAN subnet. Either way, I guess there is a reason for that ?
