Cisco ISR 892 Problem Configuring PPPoE
thomas.busse
Hello Guys,
I'm trying to configure a PPPoE Connection on an Cisco ISR 892 Router. And after my first attempts went wrong, I took a look into the official Cisco Configuration Guide telling me I did nothing wrong ... so fare so good, atteched is an excerpt of my Configuration.
And the Problem I'm facing is, that my Router IOS doesn't seem to know the vpdn-group 1 --> protocol pppoe command. I already tryed different IOS Versions but no change.
Any suggestions on how so fix this? Or is this a general IOS Bug ??
Best regards.
Thomas
IOS Versions tryed:
c890-universalk9-mz.151-3.T.bin
c890-universalk9-mz.151-3.T2.bin
c890-universalk9-mz.152-1.T.bin
Configuration excerpt:
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe #Command making problems
interface GigabitEthernet0
description *** Outside to S-DSL ***
no ip address
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
no shutdown
interface Dialer1
description *** Internet-IP: XXX.XXX.XXX.XXX ***
ip address negotiated
no ip access-group protected in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
encapsulation ppp
ip tcp adjust-mss 1452
load-interval 30
dialer pool 1
dialer remote-name xyz
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname abc
ppp chap password 123
ppp pap sent-username abc password 123
cadet alain
AFAIK You don't need this part, the config you posted from G0 onward is ok and it should work.
Regards.
Alain.
cadet alain
Regards.
Alain.
Hi Alain,
thanks for your fast respond, Router is up and assigned an IP Address now.
Grettings
Thomas
I am having some difficulties too. Command that you colored red also unable entered by me. What was the solution? Did you keep going?
