Cisco ISR C1111-4PLTEP Features
techsupport
Is the below features are with Cisco C1111-4PLTEP Router ?
LTE TDD: uplink rate of 10 Mbit/s and downlink rate of 112 Mbit/s Dual Carrier High Speed Packet Access Plus (DC-HSPA+): uplink rate of 5.76 Mbit/s and downlink rate of 42 Mbit/s High Speed Packet Access Plus (HSPA+): uplink rate of 5.76 Mbit/s and downlink rate of 21.6 Mbit/s TD-HSPA: uplink rate of 2.2 Mbit/s and downlink rate of 2.8 Mbit/s (TD-SCDMA) packet switched (PS): uplink rate of 384 kbit/s and downlink rate of 2.8 Mbit/s WCDMA (PS): uplink rate of WCDMA  (PS): uplink rate of 384 kbit/s and downlink rate of 384 kbit/s  (WCDMA CS): uplink rate of
64 kbit/s and downlink rate of 64 kbit/s (EDGE): uplink rate of 236.8 kbit/s and downlink rate of 236.8 kbit/s (GPRS): uplink rate of 85.6 kbit/s and downlink rate of 85.6 kbit/s
Prem
mgrabovs
I'm not sure about that model, maybe you meant to say 'C1101-4PLTEP'?
Anyways, I suggest going through the data sheet for the ISR1K, which you can find it below:
Cisco 1000 Series Integrated Services Routers Data Sheet
Thank you.
Marin Grabovschi
