ASR 1001-X vs ASR 1001-HX
lowhongni
Hi there,
i would like to know is there any different in term of configuration for these 2 models of router?
or any specify configuration?
mgrabovs
The ASR1001-HX is an upgrade compared to the ASR1001-X because of its capabilities.
ASR1001-HX allows more built-in SFP GE ports (up to 12), compared to ASR1001-X which goes up to 6.
Also, the HX model has more TenGigabit Ethernet ports, which allows for a higher traffic throughput compared to the other model.
In terms of configuration, both run IOS-XE. It is the same way of configuring on both, no need for any specific configuration in order to have the routers running. It is just a matter of capabilities.
Thank you.
Marin Grabovschi
6 Replies 6
marce1000
 - FYI : https://www.cisco.com/c/en/us/products/routers/asr-1000-series-aggregation-services-routers/models-comparison.html
 M.
balaji.bandi
I do not see major difference other than 1 have NIM Slot (- X Mode) - HX come with fixed.
BB
Sir, meaning that if the person knows how to configure ASR 1001-X, he/she also will know how to configure ASR 1001-HX? same way of configuration?
sure it not make any diffrence in config wise.
BB
mgrabovs
Thank you.
Marin Grabovschi
Thanks Marin. Really appreciated.
