Cisco ISR C1111-8 and L2TP Server
Hello
On the C111-8P router, I configured L2TP Server with IPSec.
When trying to connect, I get the following error:
% FMANRP_ESS-4-FULLVAI: Session creation failed due to Full Virtual-Access Interfaces not being supported. Check that all applied Virtual-Template and RADIUS features support Virtual-Access sub-interfaces. swidb = 0x7F72CCED30, ifnum = 31
Software Version: Cisco IOS XE Software, Version 16.09.07
Configuration under the spoiler:
Spoiler
RT-CISR-01#sh running-config
Building configuration...
Current configuration : 8472 bytes
! Last configuration change at 23:17:39 MSK Sat Sep 11 2021
! NVRAM config last updated at 23:17:42 MSK Sat Sep 11 2021
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 250000
hostname RT-CISR-01
boot-start-marker
boot system bootflash:/c1100-universalk9_ias.16.09.07.SPA.bin
boot-end-marker
enable secret 5 $1$z60f$mn9O8Gq3bJ0OIfpKzS7GV.
aaa new-model
aaa authentication ppp default local
aaa authorization network default local
aaa session-id common
clock timezone MSK 3 0
ip nbar http-services
ip name-server 8.8.8.8 8.8.4.4
ip domain name vts.loc
ip dhcp excluded-address 10.136.1.1 10.136.1.10
ip dhcp excluded-address 10.36.1.1 10.36.1.10
ip dhcp excluded-address 10.36.2.1 10.36.2.10
ip dhcp excluded-address 10.36.3.1 10.36.3.10
ip dhcp excluded-address 10.36.36.1 10.36.36.10
ip dhcp excluded-address 10.36.254.1 10.36.254.10
ip dhcp excluded-address 10.36.254.0
ip dhcp excluded-address 10.36.254.255 255.255.255.255
ip dhcp pool VLAN_1
network 10.36.1.0 255.255.255.0
default-router 10.36.1.1
dns-server 20.20.20.1 10.36.1.1
ip dhcp pool VLAN_3
network 10.36.3.0 255.255.255.0
default-router 10.36.3.1
dns-server 20.20.20.1 10.36.3.1
ip dhcp pool VLAN_2
network 10.36.2.0 255.255.255.0
default-router 10.36.2.1
dns-server 20.20.20.1 10.36.2.1
ip dhcp pool VLAN_36
network 10.36.36.0 255.255.255.0
default-router 10.36.36.1
dns-server 20.20.20.1 10.36.36.1
ip dhcp pool L2TP_POOL
network 10.36.254.0 255.255.255.0
dns-server 10.36.254.1
domain-name vts.loc
default-router 10.36.254.1
login on-success log
subscriber templating
vpdn enable
vpdn session-limit 100
vpdn-group L2TP_REMOTE_USERS
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
crypto pki trustpoint TP-self-signed-2398733053
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2398733053
revocation-check none
rsakeypair TP-self-signed-2398733053
diagnostic bootup level minimal
et-analytics
username vpn_vtuchk password 0 XXXXXXXXXXXXXXXXXXXXXX
redundancy
mode none
vlan internal allocation policy ascending
track 1 ip sla 1 reachability
crypto isakmp policy 10
encr 3des
authentication pre-share
group 5
lifetime 3600
crypto isakmp key 123Qwerty!@ address 0.0.0.0 no-xauth
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode transport
crypto dynamic-map CRYPTO_MAP_REMOTE_USERS 10
set nat demux
set transform-set ESP-3DES-SHA
crypto map CRYPTO_MAP 100 ipsec-isakmp dynamic CRYPTO_MAP_REMOTE_USERS
interface Loopback1
description L2TP_VPN_ENDPOINT
ip address 10.36.254.1 255.255.255.0
interface GigabitEthernet0/0/0
description ISR-DR
no ip address
ip mtu 1452
ip nat outside
ip tcp adjust-mss 1412
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/1
description ISR-TS
no ip address
ip mtu 1452
ip nat outside
negotiation auto
pppoe-client dial-pool-number 2
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
shutdown
interface GigabitEthernet0/1/2
shutdown
interface GigabitEthernet0/1/3
shutdown
interface GigabitEthernet0/1/4
shutdown
interface GigabitEthernet0/1/5
shutdown
interface GigabitEthernet0/1/6
shutdown
interface GigabitEthernet0/1/7
shutdown
interface Virtual-Template1
ip unnumbered Loopback1
peer default ip address dhcp-pool L2TP_POOL
ppp encrypt mppe auto
ppp authentication ms-chap ms-chap-v2
interface Vlan1
ip address 10.36.1.1 255.255.255.0
ip nat inside
interface Vlan2
ip address 10.36.2.1 255.255.255.0
ip nat inside
interface Vlan3
ip address 10.36.3.1 255.255.255.0
ip nat inside
interface Vlan36
ip address 10.36.36.1 255.255.255.0
ip nat inside
interface Dialer1
description DomRu
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp mtu adaptive
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxx
ppp chap password 0 xxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxx password 0 xxxxxxxxxx
ppp ipcp dns request
interface Dialer2
description TelSvc
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 2
dialer persistent
dialer-group 2
ppp mtu adaptive
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source route-map NAT-1-DR interface Dialer1 overload
ip nat inside source route-map NAT-2-TS interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 Dialer2 253
ip access-list extended ACL_OUTSIDE_IN
ip access-list extended LAN_NAT
permit ip 10.36.0.0 0.0.255.255 any
ip sla 1
icmp-echo 8.8.8.8 source-interface Dialer1
ip sla schedule 1 life forever start-time now
ip access-list extended 197
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map track-primary-if permit 1
match ip address 197
set interface Dialer1
route-map NAT-2-TS permit 10
match ip address LAN_NAT
match interface Dialer2
route-map NAT-1-DR permit 10
match interface Dialer1
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
ntp logging
ntp source Dialer2
ntp server 0.ru.pool.ntp.org
end
chances are that this is caused by the MPPE encryption and/or the ms-chap. Try and remove that from the virtual template:
--> no ppp encrypt mppe auto
--> ppp authentication chap
Hello!
Removing MPPE helped:
Thank you very much!
follow
