RV130W F/W1.0.3.55 large data transfer = interrupts data transfer
Marek SZEWCZYK
Sometimes, with many Windows updates, the router interrupted the transfer and required a restart. After installing the Bitdefender Cloud Gravity Zone clients, I have to restart the router very often. Interestingly, there is always: WAN (Internet) Information details State: Up. There is no newer firmware. I am afraid that increasing the internet bandwidth from 30 MB to 100 MB will result in non-stop reboots. I don't know how to fix the problem. Can someone help me.
2 Accepted Solutions
marce1000
  - Is there anything in the logs when this happens ?
 M.
 - Definitely looks related to bugs , if a already on latest firmware file a ticket
          https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
 M.
5 Replies 5
marce1000
 M.
Thank you, I turned on the logs. They return incomprehensible to me records.
Show it here. M.
 M.
Marek SZEWCZYK
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL1_REG: 0
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL2_REG: 0
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL0_REG: 0
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL0_REG: 80002e00
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL1_REG: 11bbcc
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL2_REG: dd800fff
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL0_REG: 88000a00
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL1_REG: 112233
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL2_REG: 55000032
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL0_REG: 88000c00
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL2_REG: 55110002
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL0_REG: 88002800
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL2_REG: dd700046
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] CNS3XXX_ARL_TABLE_ADD
2021-09-16 11:47:54 RV130W kern.warning pppoe_device_event: dev=a588a800, devname=vlan2004, event=5
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL0_REG: 8a000a00
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL1_REG: 3cce738f
2021-09-16 11:47:54 RV130W kern.warning [kernel mode] VLAN_CTRL2_REG: fda80001
2021-09-16 11:47:54 RV130W kern.warning pppoe_device_event: dev=a58b4000, devname=br0, event=5
2021-09-16 11:47:54 RV130W kern.warning pppoe_device_event: dev=a44a9800, devname=vlan1, event=8
2021-09-16 11:47:54 RV130W kern.warning pppoe_device_event: dev=a58b4000, devname=br0, event=8
2021-09-16 11:47:54 RV130W kern.warning pppoe_device_event: dev=a44a9800, devname=vlan1, event=13
2021-09-16 11:47:54 RV130W kern.warning pppoe_device_event: dev=a58b4000, devname=br0, event=13
2021-09-16 11:47:54 RV130W kern.warning pppoe_device_event: dev=a58b6000, devname=br2004, event=5
2021-09-16 11:47:54 RV130W kern.warning pppoe_device_event: dev=a58b6000, devname=br2004, event=8
2021-09-16 11:47:54 RV130W kern.warning pppoe_device_event: dev=a588a800, devname=vlan2004, event=13
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a58b6000, devname=br2004, event=13
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a653cc00, devname=eth3, event=13
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a4884400, devname=wl0.1, event=5
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a792d800, devname=wl0.2, event=5
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a58aec00, devname=wl0.3, event=5
2021-09-16 11:47:55 RV130W kern.warning COEX: downgraded chanspec 0x1808 to 0x1006: channel 3 used by exiting BSSs
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a4884400, devname=wl0.1, event=13
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a792d800, devname=wl0.2, event=13
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a58aec00, devname=wl0.3, event=13
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:find_free_index,Line:152--->CUSTOM_INDEX_SUPPORT is enable
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:find_free_index,Line:166--->find_free_index ++++++add dev index: 10, vif index: 0
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:find_free_index,Line:166--->find_free_index ++++++add dev index: 13, vif index: 1
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:find_free_index,Line:166--->find_free_index ++++++add dev index: 14, vif index: 2
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a7b40000, devname=eth1, event=13
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a7b40000, devname=eth1, event=4
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a5936400, devname=vlan2, event=5
2021-09-16 11:47:55 RV130W kern.warning gsw_vlan_rx_register
2021-09-16 11:47:55 RV130W kern.warning [kernel mode] VLAN_CTRL0_REG: 80002e00
2021-09-16 11:47:55 RV130W kern.warning [kernel mode] VLAN_CTRL1_REG: 11bbcc
2021-09-16 11:47:55 RV130W kern.warning [kernel mode] VLAN_CTRL2_REG: dd800fff
2021-09-16 11:47:55 RV130W kern.warning [kernel mode] VLAN_CTRL0_REG: 88000a00
2021-09-16 11:47:55 RV130W kern.warning [kernel mode] VLAN_CTRL1_REG: 112233
2021-09-16 11:47:55 RV130W kern.warning [kernel mode] VLAN_CTRL2_REG: 55000032
2021-09-16 11:47:55 RV130W kern.warning [kernel mode] VLAN_CTRL0_REG: 88000c00
2021-09-16 11:47:55 RV130W kern.warning [kernel mode] VLAN_CTRL2_REG: 55110002
2021-09-16 11:47:55 RV130W kern.warning [kernel mode] CNS3XXX_ARL_TABLE_ADD
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a5936400, devname=vlan2, event=8
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a5936400, devname=vlan2, event=13
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a5936400, devname=vlan2, event=9
2021-09-16 11:47:55 RV130W kern.warning pppoe_flush_dev:(294) dev=a5936400, nd_net=a042f280
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a5936400, devname=vlan2, event=2
2021-09-16 11:47:55 RV130W kern.warning pppoe_device_event: dev=a5936400, devname=vlan2, event=4
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:vif_delete_dev,Line:229--->vif_delete_dev ------dev index: 14, vif_index:2, maxvif: 3
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:free_used_index,Line:207--->free_used_index vif_index: 2
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:vif_delete_dev,Line:229--->vif_delete_dev ------dev index: 13, vif_index:1, maxvif: 2
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:free_used_index,Line:207--->free_used_index vif_index: 1
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:vif_delete_dev,Line:229--->vif_delete_dev ------dev index: 10, vif_index:0, maxvif: 1
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:free_used_index,Line:207--->free_used_index vif_index: 0
2021-09-16 11:47:55 RV130W kern.warning file:net/ipv4/ipmr.c,function:find_free_index,Line:166--->find_free_index ++++++add dev index: 18, vif index: 3
2021-09-16 11:47:55 RV130W kern.warning eth3: received packet with own address as source address
