Cisco isr g2 3925 troughput/maxspeed
AHMADJ
have seen this document but it is not showing clear statement can you please just update me with below details
1-Router throughput capability: ?????
2-Maximum Bandwidth can support:??????
2 Accepted Solutions
Leonid Voronkin
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
Lenoid has provided the tables from the document I'm unable to attach.
As noted, and as can be seen, the 3925's performance is highly variable, depending on how you use it.  I.e. it's performance depends on both your configuration and the traffic it's processing.
If you're wondering why Cisco's recommendation is about half of the "worst" case, that's because you'll need to remember to allow for duplex bandwidth on many links.  The performance tables are aggregate performance for all traffic passing through the router.
7 Replies 7
Joseph W. Doherty
What document are you referring to?
I've attached a Cisco paper that well describes a 3925's performance under different conditions.  ("Different conditions" is important to understand because a 3925's effective performance is very variable.)
Attachments aren't attaching!
Trying a new reply . . .
...appears to not work!
balaji.bandi
attached some performance report - this works?
BB
I am not able to find attachment
balaji.bandi
Looks having some issue attaching the document, a contacted the community manager to fix.
BB
Leonid Voronkin
