11-19-2023 08:34 AM - edited 11-19-2023 11:17 AM
Hello team, I have a question regarding licensing. I'm considering to buy Cisco ISR 1101 series router with IOS-XE. As far as I know, the default license there is IP BASE. My question is, do I need to buy this license separately? I mean does it come with the router itself? And if IP BASE license comes with Router, do I need to pay for it periodically, meaning is it subscription based license? Thank you.
11-19-2023 10:59 AM - edited 11-21-2023 06:48 AM
You need buy subecription Licese Like base default and Throuput if the base throruput not good enough :
also if you buying new deployment check the EOL of 1K Router and consider Cat 8K Models for the future
11-19-2023 11:21 AM
Hello @balaji.bandi Thank you. Your link is about ASR 1000, not about ISR 1101 (I made a typo and wrote 1001 instead of 1101 and now I corrected it). Can you please check information about license Cisco ISR 1101 series routers?
11-19-2023 11:34 AM
have updated the information - apologies.
11-20-2023 03:27 AM
@balaji.bandi Thank you. Did you change your opinion regarding paying for IP base license considering that I'm asking about ISR 1001 series and not about ASR 1000 series?
11-20-2023 06:50 AM
IPbase License free come with base image - as i have corected the document.
11-19-2023 11:54 AM - edited 11-19-2023 11:56 AM
Hello @Alek5942
Note ISR 1100 products are eol/eos.
They are ship with the IP Base license by default.
11-19-2023 01:13 PM
Hello M02@rt37 I'm considering to buy ISR 1101-4p which is not in the announcement, so maybe it's not EOL/EOS yet. My question is, if the IP Base license is default, does it mean that I don't have to pay anything to buy this license? And another question, if let's say I don't need to buy this license, do I need to pay for it periodically, meaning is it subscription based license?
11-19-2023 10:21 PM
The IP Base license is typically a perpetual license, meaning it does not have an expiration date. Once you purchase the router with the IP Base license, you own the license, and there's no need for ongoing subscription payments for that particular license.
11-20-2023 03:25 AM
M02@rt37 Thanks for the reply. I'm asking because, looks like that for example for ASR 1000 series, IP base license should be bought separately. And I want to make sure that if I'll buy ISR 1101 series, I'll not need to buy IP Base license or I will not need to pay for the subscription for IP Base license.
11-20-2023 07:06 AM
As I said, once you purchase the router with the IP Base license, you own the license, and there's no need for ongoing subscription payments for that particular license.
11-20-2023 09:45 AM
Thank you for the reply. Sorry for the bothering, and the last question to make sure. I understood about subscription, that there is no need to pay for it. And also you don't need to pay for the IP BASE license separately, this license comes with the router, correct?
11-21-2023 06:47 AM
This is cisco document and you read correctly - if you ordering the provided code.
Table 41. Cisco ISR 1000 Series licenses
11-21-2023 06:50 AM
