Cisco ISR password recovery
SS2020
Hello All,
i have a Cisco ISR router model 4321 and need to do lost password recovery but every time i follower below steps i lose current configurations.
Cisco Router password recovery step by step
Step one,get into the rommon mode by breaking into the rommon moode during the bootup.
after you into the rommon mode, change the register configuratiobs, 0x2142 as below
rommon 1 > confreg 0x2142
Step2, reset the router
rommon 2 > Reset
Step 3,Skip Initial Configuration Dialog:
Would you like to enter the initial configuration dialog? [yes/no]: no
Step 4,Skip Initial Configuration Dialog:
Enter Privileged EXEC Mode:
Router> enable
Router# copy startup-config running-config
Step 5,change the password,
Router# configure terminal
Router(config)# enable secret NEW_PASSWORD
Router(config)# exit
Step 6,Change Configuration Register Back:
Router(config)# config-register 0x2102
Router# write memory
Router# reload
can someone kindly help me to show me how to replace a lost username and password recovery without losing the current configurations please? i cannot afford to lose running configurations on the route as i do not have a backup.
Many thank you.
balaji.bandi
i follow most of the time works for me :
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/troubleshooting/guide/isr4400trbl/isr4400trbl02.html
when you are in #you can copy the config show run (to notepad) and save out of box, also make sure you make regular backup to avoid loosing the woprking config.
BB
balaji.bandi
BB
This is not working for me. I can try all day long and it will always boot to username: .
I entered rommon>1 and typed confreg 0x2142 and reset. The router reset and booted all the way to username: time after time.
I then tried https://www.cisco.com/c/en/us/td/docs/routers/access/4400/troubleshooting/guide/isr4400trbl/isr4400trbl02.html but get the same result. I have done this before and never had a problem, now on the last three 4351 ISR's I am experiencing the same symptoms, not able to log in to exec mode
Any help is appreciated.
I suggest to open a new post referring this post and post complete boot log on the new post so we can understand what is the issue.
BB
