cisco ISR4321/K9 interface throughput
imranhoque11273
Dear all,
I have a cisco ISR4321/K9 router. configured bgp with ISP.
Thing is, not getting more than 50 Mbps from LAN interface. BW taken from ISP is 70 Mbps.
Can anyone please help to understand the reason. and how to solve the issue.
sh ver output is as below-
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
KGSB-DR1 uptime is 43 weeks, 23 hours, 30 minutes
Uptime for this control processor is 43 weeks, 23 hours, 32 minutes
System returned to ROM by reload
System image file is "bootflash:/isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bi"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4321/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FDO2052A12W
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
br
imran
pman
Attaches related information:
Technical Specifications
Cisco 4461
Cisco 4451
Cisco 4431
Cisco 4351
Cisco 4331
Cisco 4321
Cisco 4221
Aggregate Throughput (Default)
1.5Gbps
1 Gbps
500 Mbps
200 Mbps
100 Mbps
50 Mbps
35Mbps
Aggregate Throughput (Performance License)
3Gbps
2 Gbps
1 Gbps
400 Mbps
300 Mbps
100 Mbps
75 Mbps
Aggregate CEF Only[5] Throughput (Boost License)
Over 7Gbps
Over 4Gbps
Over 4Gbps
Over 2Gbps
Over 2Gbps
1.5Gbps
1.2Gbps
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
