cisco ISR4331/K9 NAT UDP/TCP port-range cleanup
Starkwittie
-Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.2, RELEASE SOFTWARE (fc4)-
Hi All,
I've tried several suggestions I found on the community but without success unfortunately, and probably it will already be somewhere here on the community  but I cannot seem to find it.
I would like to cleanup the UDP NAT statements, so my config looks better.
This is what I would like to cleanup:
ip nat inside source static udp 10.10.90.201 16000 interface GigabitEthernet0/0/0 16000
ip nat inside source static udp 10.10.90.201 16001 interface GigabitEthernet0/0/0 16001
ip nat inside source static udp 10.10.90.201 16002 interface GigabitEthernet0/0/0 16002
ip nat inside source static udp 10.10.90.201 16003 interface GigabitEthernet0/0/0 16003
ip nat inside source static udp 10.10.90.201 16004 interface GigabitEthernet0/0/0 16004
ip nat inside source static udp 10.10.90.201 16005 interface GigabitEthernet0/0/0 16005
ip nat inside source static udp 10.10.90.201 16006 interface GigabitEthernet0/0/0 16006
ip nat inside source static udp 10.10.90.201 16007 interface GigabitEthernet0/0/0 16007
ip nat inside source static udp 10.10.90.201 16008 interface GigabitEthernet0/0/0 16008
ip nat inside source static udp 10.10.90.201 16009 interface GigabitEthernet0/0/0 16009
ip nat inside source static udp 10.10.90.201 16010 interface GigabitEthernet0/0/0 16010
ip nat inside source static udp 10.10.90.201 16011 interface GigabitEthernet0/0/0 16011
ip nat inside source static udp 10.10.90.201 16012 interface GigabitEthernet0/0/0 16012
ip nat inside source static udp 10.10.90.201 16013 interface GigabitEthernet0/0/0 16013
ip nat inside source static udp 10.10.90.201 16014 interface GigabitEthernet0/0/0 16014
ip nat inside source static udp 10.10.90.201 16015 interface GigabitEthernet0/0/0 16015
I've read things about route map but this command my router does not accept.
Any ideas?
Thanks a lot in advance
Hello
Below is a possible solution however you mention your ios doesn't support route-maps correct?
access-list 100 permit udp host 10.10.90.201 range 1600 16015 any range 1600 16015
route-map UDP
match ip address 100
ip nat inside source static 10.10.90.201 10.10.90.201 route-map UDP extendable
EDITED
Looks like @pieterh as mentioned it already , i did also find a possible alternative to a nat route-map using NAT portmap which seems positive how ever ive never used it before and at present cannot test it.
access-list 1 permit 10.10.90.201
ip nat portmap UDP
appl udp-rtp startport 16000 size 16064
ip nat inside source list 1 interface x/x overload portmap UDP
Kind Regards
Paul
Hi Paul,
it is supposed to be supported from IOS 12.x and I have 16.x:
And this is working ip nat inside source static 10.10.90.201 10.10.90.201 route-map UDP extendable
But it seems it has a problem with the WAN interface, so this is not working as it needs to come in from WAN to LAN or am I seeying this wrong?
ip nat inside source static 10.10.90.201 interface GigabitEthernet0/0/0 route-map UDP extendable
gives:
TMROUTER01(config)#ip nat inside source static 10.10.90.201 interface GigabitEthernet0/0/0 route-map UDP extendable
% Invalid input detected at '^' marker.
Best regards
Glenn Verhoeven
pieterh
look at this post
no route map,  but ip nat portmap
check if your IOS version supports this command.
and this post that says:
If you notice on the last command that you are not allowed to use a route-map on an interface so I had to type in the WAN ip address.
