Trouble getting two applications working
dariely_ann
I have a laptop acting as a server. The laptop's IP address is 192.168.100.5.
To access Application A from the laptop you have to use the IP address 192.168.100.5:7004
Application B is a mobile app and its managed by the laptop, so Application B has to be 192.168.100.5 (or not?). Right now, I can only access Application B using 50.225.255.196.
I have the following NAT commands on my router:
ip nat source static tcp 192.168.100.5 80 50.225.225.196 80 extendable
ip nat source static tcp 192.168.100.5 443 50.225.225.196 443 extendable
ip nat source static 192.168.100.5 50.225.225.196
Another thing, Application B talks to Application A
We keep losing the network connection to the laptop. If I remove the NAT commands, Application A works fine. If I add the commands Application A and Application B work, but after a day or two they don't work no more.
When it no longer works it says that 192.168.100.5 is a duplicate (I can see why), when I remove Application B from the equation, the duplicate error goes away.
How can I make these two applications work with each other on the same laptop, and give Application B a public IP address?
My current configuration is a Router in a Stick.
Hello
Can you post a topology of this setup so it can be visualized on what you are doing?
Kind Regards
Paul
dariely_ann
Below is my router-config, I removed all irrelevant information. Attached is a quick simple topology.
version 15.6
hostname Router_Academic_Network
boot-start-marker
boot system flash0:c2900-universalk9-mz.SPA.156-3.M6.bin
boot-end-marker
interface GigabitEthernet0/0
description Uplink to Firewall
ip address 50.225.225.146 255.255.255.252
no ip redirects
ip nat enable
ip virtual-reassembly in max-reassemblies 1000
duplex full
speed 1000
no cdp enable
interface GigabitEthernet0/1
description Uplink_to_Switch_Academic_Network
no ip address
no ip redirects
ip nat enable
duplex full
speed 1000
interface GigabitEthernet0/1.200
description Digital_Signage
encapsulation dot1Q 200
ip address 192.168.100.1 255.255.255.0
ip nat enable
ip nat source list 10 interface GigabitEthernet0/0 overload
ip nat source list NAT interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 50.225.225.145
ip ssh authentication-retries 5
ip ssh version 2
ip access-list extended NAT
permit ip 192.168.100.0 0.0.0.255 any
deny tcp any any
deny udp any any
access-list 20 permit 192.168.100.0 0.0.0.255
access-list 20 deny any log
