Cisco ISR4331/K9 router errors out of box
p_atkinson
I’m receiving errors on a new Cisco ISR4331/K9 router that I haven't done any configurations on. I was hoping someone could shed some light on why the
following messages are coming up on startup.
Error1:
no valid BOOT image found
Final autoboot attempt from default boot device...
Located isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
Error 2 - Interface errors:
interface Vlan1
% Invalid input detected at '^' marker.
no ip address
% Incomplete command.
shutdown
SETUP: new interface Vlan1 placed in "shutdown" state
BELOW IS BOOT:
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.7(2r), RELEASE SOFTWARE
Copyright (c) 1994-2017  by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4331/K9 platform with 4194304 Kbytes of main memory
Package header rev 1 structure detected
IsoSize = 471482368
Calculating SHA-1 hash...Validate package: SHA-1 hash:
        calculated 92A40F6F:F8586BC3:F00F114B:EFB43257:B9728643
        expected   92A40F6F:F8586BC3:F00F114B:EFB43257:B9728643
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
%IOSXEBOOT-4-BOOT_SRC: (rp/0): mounting /boot/super.iso to /tmp/sw/isos
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ISR4331/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FLM2147W0SR
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
interface Vlan1
no ip address
shutdown
Press RETURN to get started!
*Apr 30 21:04:19.156: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Apr 30 21:04:20.741: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = ipbasek9
*Apr 30 21:04:21.891: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Apr 30 21:04:26.497: dev_pluggable_optics_selftest attribute table internally inconsistent @ 0x144
*Apr 30 21:04:30.414: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Apr 30 21:04:31.418: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Apr 30 21:04:31.418: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Apr 30 21:04:31.418: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Apr 30 21:04:31.427: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Apr 30 21:04:32.760: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Apr 30 21:04:32.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Apr 30 21:04:32.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Apr 30 21:04:32.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Apr 30 21:04:32.812: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Apr 30 21:04:32.812: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Apr 30 21:04:34.835: %SYS-5-CONFIG_I: Configured from memory by console
*Apr 30 21:04:34.840: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Apr 30 21:04:34.842: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Apr 30 21:04:34.847: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Apr 30 21:04:34.847: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Apr 30 21:04:34.848: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Apr 30 21:04:34.848: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Apr 30 21:04:34.851: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Apr 30 21:04:34.851: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Apr 30 21:04:34.857: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Apr 30 21:04:34.898: %SPA-3-ENVMON_NOT_MONITORED: SIP1: iomd:  Environmental monitoring is not enabled for ISR4331-3x1GE[0/0]
*Apr 30 21:04:36.296: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Apr 30 21:04:36.835: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
*Apr 30 21:04:37.517: %SYS-6-BOOTTIME: Time taken to reboot after reload =  268 seconds
*Apr 30 21:04:39.624: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
SH RUN
Router#sh run
Building configuration...
Current configuration : 1182 bytes
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
subscriber templating
license udi pid ISR4331/K9 sn FDO21410WKW
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
End
SH HARD
Router#sh hard
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
software.
ROM: IOS-XE ROMMON
Router uptime is 32 minutes
Uptime for this control processor is 33 minutes
System returned to ROM by reload
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: Reload Command
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             None             None
uck9             None             None             None
securityk9       None             None             None
ipbase           ipbasek9         Permanent        ipbasek9
Deepak Kumar
I think, you updated the IOS / deleted from flash but didn't update the boot maker.
try with below command:
boot-start-marker
boot system flash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
exit
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thank You so much for your quick response. The router IOS was not upgraded actually. I took it out of the box and the errors that displayed were the ones from the factory install. After adding the config line to the router "boot system flash isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin" the error "no valid BOOT image found" is gone.
I was wondering if you or anyone else would know about the interface errors
interface Vlan1
no ip address
shutdown
They show up at the end of the bootup process
interface Vlan1
 no ip address
 shutdown
Leo Laohoo
Error message is fine.
p_atkinson
I ended up being able to put a support case in with cisco and the solutions were:
1) Add line "boot system flash bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin" to config to get rid of error no valid BOOT image found
2) I would have to install a NIM-ES2-8-P card to remove the Vlan interface errors
Thank You for your replies.
Paul
