cisco isr4331 throughput upgrade
remus.delavega
Hi everyone,
May I ask if it is ok to buy a performance license and use it on a router that has an old firmware version? We are worried if it might take effect or not.
This is the current firmware version
bootflash isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
ISR4331 K9
Purchase the PAK and apply it.
Leo Laohoo
Post the complete output to the following commands:
  1. sh platform hardware throughput level
  2. sh license feature
Thanks for the quick response. Kindly find the output below.
The current throughput level is 100000 kb/s
sh license feature
Feature name Enforcement Evaluation Subscription Enabled RightToUse
appxk9 yes yes no no yes
uck9 yes yes no no yes
securityk9 yes yes no yes yes
ipbasek9 no no no yes no
FoundationSuiteK9 yes yes no no yes
AdvUCSuiteK9 yes yes no no yes
cme-srst yes yes no no yes
hseck9 yes no no no no
throughput yes yes no no yes
internal_service yes no no no no
balaji.bandi
You need to buy a traditional License and install the License, router required a reboot to get effective.
https://www.cisco.com/c/en/us/support/docs/routers/4000-series-integrated-services-routers/217135-performance-license-on-cisco-isr4000.html
Table 4.             Specifications of Cisco 4000 Family Integrated Services Routers
Technical Specifications
Cisco 4461
Cisco 4451
Cisco 4431
Cisco 4351
Cisco 4331
Cisco 4321
Cisco 4221
Aggregate Throughput (Default)
1.5Gbps
1 Gbps
500 Mbps
200 Mbps
100 Mbps
50 Mbps
35Mbps
Aggregate Throughput (Performance License)
3Gbps
2 Gbps
1 Gbps
400 Mbps
300 Mbps
100 Mbps
75 Mbps
Aggregate CEF Only[5] Throughput (Boost License)
Over 7Gbps
Over 4Gbps
Over 4Gbps
Over 2Gbps
Over 2Gbps
1.5Gbps
BB
