04-05-2022 09:25 AM
Metric can be used between iBGP? whether it works only between eBgp neighbors(between AS)?
04-05-2022 09:29 AM - edited 04-05-2022 10:36 AM
If you are referring to MED then yes it works with EBGP only.
Jon
04-05-2022 09:31 AM - edited 04-05-2022 10:49 AM
there are two metric
IGP metric and MED Metric
MED metric usually use between eBGP
IGP metric usually use between iBGP
Do show ip bgp route x.x.x.x
if the route learn from iBGP you will see IGM metric
if the route learn from eBGP you will see MED metric if config
04-05-2022 10:44 AM
Hi @gowdakssujan ,
Although it is typically used for eBGP, the BGP MED works for both iBGP and eBGP.
04-05-2022 11:19 AM
Harold
Did not know that.
Thanks for correcting.
Jon
