CISCO ISR4331-V/K9 BTU - heat dissipation
Fabian_
Hi Community,
a customer ask me, how is the heat dissipation from the CISCO ISR4331-V/K9. I don't find it in the data sheet. Could help me someone?
Any Quick Reply will be appreciated.
Thanks a lot
Fabian
inderdeeps
Level 4
Level 4
@Fabian_ : make sure you understand,
Power consumption to Heat dissipation
60 W: 205 BTU/hr (configuration dependent)
250 W : 853 BTU/hr (configuration dependent)
inderdeeps
Level 4
Level 4
Hi Inderdeeps,
thanks for your help!
