ASR 903 IOS upgrade
vin.marco
Hello everybody
I'm planning to upgrade my ASR-903 Dual RP Routers.
The update is from 15.6 (2) SP2 to 17.3 (3) SPA.
Do you think I have to install 16 first?
This is the show version and the show platform.
XXXXXXXX#sh ver
Cisco IOS XE Software, Version 03.18.02.SP.156-2.SP2-ext
Cisco IOS Software, ASR900 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.6(2)SP2, RELEASE SOFTWARE (fc2)
XXXXXXXXX#sh platform
Chassis type: ASR-903
Slot      Type                State                 Insert time (ago)
 0/1      A900-IMA8S1Z        ok                    5w0d
 0/3      A900-IMA8S1Z        ok                    5w0d
 0/4      A900-IMA8Z          ok                    5w0d
 0/5      A900-IMA8Z          ok                    5w0d
R0        A900-RSP3C-400-S    ok, active            5w0d
R1        A900-RSP3C-400-S    ok, standby           5w0d
F0                            ok, active            5w0d
F1                            ok, standby           5w0d
P0        A900-PWR1200-A      ok                    5w0d
P1        A900-PWR1200-A      ok                    5w0d
P2        A903-FAN            ok                    5w0d
Slot      CPLD Version        Firmware Version
R0        16040627            15.6(20r)S
R1        16040627            15.6(20r)S
F0        16040627            15.6(20r)S
F1        16040627            15.6(20r)S
Should I also update the ROMMON?
Thank you
Leo Laohoo
ROMMON upgrade will be mandatory.
Direct upgrade to 16.X.X or 17.X.X is possible if ROMMON has been upgraded.
Thanks Leo for the reply.
I would like to ask two questions:
  1.  To upgrade to  version 17.3 (3)SPA, which ROMMON version should I install?
  2. From the show version, installed IOS is 15.6 or 3.18
Thanks again.
 -FYI : https://www.cisco.com/c/en/us/td/docs/routers/asr903/release/notes/17-3-1/b-rn-xe-17-3-1-asr900/m-intro-17-2-x-asr900.html?bookSearch=true#Cisco_Concept.dita_447324fa-ee49-4608-91ac-fccf8010eee8
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Whatever is the latest that is supported by the RSP.
@vin.marco wrote:
  1. From the show version, installed IOS is 15.6 or 3.18
Old "name" is 15.6 and the new "name" is 3.18.X.
