Cisco Linksys EA4500 shared to cisco switch
Francis Jr Asis
I have 3560 X and i made this as a layer 3(IP ROUTING) and my problem is how can i connect this switch to the Linksys EA4500 model router which my source of internet connection. I attached the config for the core switch. Any help please
devils_advocate
Level 7
Level 7
Configure the uplink port on the 3560 with an IP address in the same range as your Router and then configure a default route on the 3560 to point to the IP address of the router.
#interface Gi1/0.*
#no switchport
#ip address 192.168.100.10 255.255.255.0
#ip route 0.0.0.0 0.0.0.0 192.168.100.1
Also, if you are using that username and password for your switch, I would consider changing them
5 Replies 5
devils_advocate
Level 7
Level 7
#interface Gi1/0.*
#no switchport
i did that way but they said i need to make routing also in the Linksys EA4500 that point to the 192.168.100.2  address.
what do you mean about the username and password for the switch?
paolo bevilacqua
Wrong forum, post in "LAN and switching". You can move your posting with the Actions panel on the right.
THere is routing on it.this is layer 3 switch
m-abooali
Level 4
Level 4
I am having same problem except my Sw is a Cisco 3750. I have done as I also see here but still I cannot make sw and Linksys talk. I am assuming on linksys one must use rbridge or other protocols like PPoE, etc. rather than static option. I'm still dealing with the problem. I had this workingh using a Cisco 3550 Sw but replacing 3550 to 3750 showing this problem.!? what resolved your issues?
