Cisco Local LAN issue
kumarpmt83
hi,
In my office they given me one task in the network..
My setup:
We have a PTP to connection b/w our office.
One is headoffice and other is client office.
i have problem in  the client office and  that office totally 300 users.
We have a allocate Lan network as 10.20.235.0/23.There is two departments.
we allocate one dept for 10.20.234.0/24 and other dept for 10.20.235.0/24.
we want to both IP should not be communicate in the local lan network..But both we want communicate the headoffice servers.
I have one cisco 1841 router and 7 HP L2 managable switches.
What IP to be given the LAN interface and which gateways to be  given to the Two depts.
In the headoffice already i am given static route.and the PTP link is working.
Kindly tell me what am i do???
fb_webuser
Level 6
Level 6
Seems like you need to separate two departments using one router.
So, if VLAN 100 = 10.20.234.0/24 and VLAN 200 = 10.20.245.0/24
This configuration is from memory, so it is probably not without flaws;
On the 1841 router:
interface F0/0
description WAN interface
ip address 33.33.33.2 255.255.255.252
ip route 0.0.0.0 0.0.0.0 33.33.33.1 name DEFAULT
interface F0/1
description LAN interface
interface F0/1.100
encapsulation dot1Q 100
ip address 10.20.234.1 255.255.255.0
no ip proxy-arp
ip access-group ACL_100 in
interface F0/1.200
encapsulation dot1Q 200
ip address 10.20.235.1 255.255.255.0
no ip proxy-arp
ip access-group ACL_200 in
ip access-list extended ACL_100
deny ip 10.20.234.0 0.0.0.255 10.20.235.0 0.0.0.255 log
permit ip any any
ip access-list extended ACL_200
deny ip 10.20.235.0 0.0.0.255 10.20.234.0 0.0.0.255 log
permit ip any any
On the HP switch connected to the 1841 router you need to tag VLAN 100 and VLAN 200, and make the uplink port a tagged port.
Remember to create the VLANs on all switches, and to tag the VLANs on all inter-switch links.
This would be a basic configuration for what you are asking
It is also possible to do this in many other ways, for example VLANs connected to VRFs and even transported with MPLS, but I think this is probably what you were looking for.
Good luck
Atle
Posted by WebUser Atle Ørn Hardarson
Thanks for your valuable information.
I have one question .
If some users are want to communicate b/w the VLAN means what am i do .
If it is possible???
not familiary with the 1841 router but having a firewall maybe a good idea as you only need some users to be able to communicate with the other department.
fb_webuser
Level 6
Level 6
Yes, if you want some devices to communicate, but not others, you can modify your ACLs as such:
remark Permit FTP for server A to VLAN 200
permit tcp host 10.20.234.20 10.20.245.0 0.0.0.255 eq 21
remark Permit Print for Server A to Server on VLAN 200
permit tcp host 10.20.245.20 host 10.20.245.20 eq 9100
remark Deny everything else between subnets
deny ip any any
This is all for IPv4. Remember, if you deploy IPv6, the same goes for IPv6.
PS: if you require more complex rules, it is possible to configure a zone-based firewall on IOS, or if the access is user-based and not always IP-based, you can install a ASA 5K firewall and use LDAP "snooping" if there is a directory service present, like Active Directory.
Atle
