Cisco Model 881 - Unable to NAT to web server
isaaczhun
I hope there any someone here can help me out.
Apparently the problem seems simple enough however I couldn't get it working. My router is being configured to access a web server in the network which is on port 80. However, port 80 is being used by my router's setup page. Therefore whenever I key in my public IP address, it will just immediately direct me to the router's page.
I have also tried opening up other ports like 5050 and set my web server to port 5050. Internally within the LAN itself everyone can access the web server with port 5050. However, going from public IP address with port 5050 doesn't work. Am I missing anything here?
All the firewalls are configured.
Thanks in advanced.
45 Replies 45
  You need to see connections on your router when testing from the internet.  This is not correct, tcp xxx.xxx.xxx.xxx:5050 192.168.1.39:80  ---
Pleast post "show running" here again. If it works with tcp/21 and tcp/1723. It should not be a problem with tcp/5050.
Toshi
Hi Toshi,
Therefore I shouldn't be using the same internet connection as the server if that is what you mean?
   If I open web browser or do telnet on my pc now, you should see connections. And you already did telnet or console to router to type "show ip nat trans" and "show access-l"  at the same time. Yes,I'm in the internet. This is what we want to test.
Post the result of command below
Router#telnet 192.168.1.39 5050 /source-interface fastether4
Toshi
Hi Toshi,
I type in "! Router#telnet 192.168.1.39 5050 /source-interface fastether4 !"
however there is no result showing. Just like pressing enter again.
Result:
xxx10M#$net 192.168.1.39 5050 /source-interface fastether4!
xxx10M#
    Please do this
xxx10M#telnet 192.168.1.39 5050 /source-interface fastether4
Toshi
Hi Toshi,
I'm seeing my WAMP server stuff coming out
Trying 192.168.1.39, 5050 ... Open
^C
        "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
        WAMPSERVER Homepage
  • Version 2.1
  • Version Française
    Server Configuration
    Apache Version :
    2.2.17
    PHP Version :
    5.3.5
    Loaded Extensions :
    • Core
    • bcmath
    • calendar
    • com_dotnet
    • ctype
    • date
    • ereg
    • filter
    • ftp
    • hash
    • iconv
    • json
    • mcrypt
    • SPL
    • odbc
    • pcre
    • Reflection
    • session
    • standard
    • mysqlnd
    • tokenizer
    • zip
    • zlib
    • libxml
    • dom
    • PDO
    • Phar
    • SimpleXML
    • wddx
    • xml
    • xmlreader
    • xmlwriter
    • apache2handler
    • gd
    • mbstring
    • mysql
    • mysqli
    • pdo_mysql
    • pdo_sqlite
    • pdf
    • mhash
    • xdebug
      MySQL Version :
      5.5.8
      Tools
      • phpinfo()
      • phpmyadmin
        Your Projects
        • system
        • test
        • website
          Your Aliases
          • phpmyadmin
          • sqlbuddy
          • webgrind
          • http://www.wampserver.com">WampServer
          • http://www.wampserver.com/en/donations.php">Donate
          • http://www.alterway.fr">Alter Way
            [Connection to 192.168.1.39 closed by foreign host]
               Okay. Please post the current running configuraion.
            xxx10M#show running.
            Toshi
            interface FastEthernet0
            interface FastEthernet1
            interface FastEthernet2
            interface FastEthernet3
            interface FastEthernet4
            description 00062299sng$ES_WAN$
            ip address xx.xx.xx.xx 255.255.255.252
            ip nat outside
            ip virtual-reassembly
            duplex full
            speed 100
            interface Vlan1
            description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
            ip address xx.xx.xx.xx 255.255.255.240 secondary
            ip nat inside
            ip tcp adjust-mss 1452
            ip forward-protocol nd
            ip http server
            ip http access-class 23
            ip http authentication local
            ip http secure-server
            ip http timeout-policy idle 60 life 86400 requests 10000
            ip dns server
            ip nat inside source list 1 interface FastEthernet4 overload
            ip nat inside source static tcp 192.168.1.39 21 interface FastEthernet4 21
            ip nat inside source static tcp 192.168.1.201 1723 interface FastEthernet4 1723
            ip nat inside source static tcp 192.168.1.39 5050 interface FastEthernet4 5050
            ip route 0.0.0.0 0.0.0.0 xx.xx.xx.xx
            access-list 1 permit 192.168.1.0 0.0.0.255
            no cdp run
              Okay , Just read your private message.
            Toshi
            See reply.
              I'm 100% sure that we cannot open connections to your router with tcp/5050. Then ask your ISP.  I'm 100% sure that you can use TCP/80(http) to connect to your web server.
              Please change the port on web server to TCP/80.  And we will test it.
            Toshi
            Hi Toshi,
            I have changed it to port 80 for the web server. However by typing the public ip address to the URL it is still going to the router setup page.
              No, Its not. I saw WampServer Apache Server 2.2.17.  It's working like a charm. Where are you testing from?
              Keep in mind you need to test when you're not in Local LAN 192.168.1.0/24 and you can access the internet.
            Toshi
            Kept forgetting I'm on LAN.
            If you saw it then it should be working fine.
            Thanks for the help!
               Hahaha....  It's okay
            Toshi
