Cisco Model 881 - Unable to NAT to web server
isaaczhun
I hope there any someone here can help me out.
Apparently the problem seems simple enough however I couldn't get it working. My router is being configured to access a web server in the network which is on port 80. However, port 80 is being used by my router's setup page. Therefore whenever I key in my public IP address, it will just immediately direct me to the router's page.
I have also tried opening up other ports like 5050 and set my web server to port 5050. Internally within the LAN itself everyone can access the web server with port 5050. However, going from public IP address with port 5050 doesn't work. Am I missing anything here?
All the firewalls are configured.
Thanks in advanced.
  No, Its not. I saw WampServer Apache Server 2.2.17.  It's working like a charm. Where are you testing from?
  Keep in mind you need to test when you're not in Local LAN 192.168.1.0/24 and you can access the internet.
Toshi
45 Replies 45
cadet alain
I think it would be simpler for us to help if we had more infos like the running config for instance.
Regards.
Alain.
where can I get the running config as the whole installation is done by another vendor.
connect to router with console cable then type enable enter the privileged password then type sh run and then press enter multiple times until the end of this config then select all copy and paste and post here.
Regards.
Alain.
Hi Cadet alain,
I tried connecting my router with a console cable and use putty to connect it. However, after waiting for a long time the screen is still blank. Any idea how to fix this?
Sorry I'm very new to all these stuff.
Hi Cadet Alain,
I'm able to extract them out already.
Following are the config for NAT. Is there anything wrong here?
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.1.39 21 interface FastEthernet4 21
ip nat inside source static tcp 192.168.1.201 1723 interface FastEthernet4 1723
ip nat inside source static tcp 192.168.1.39 5050 interface FastEthernet4 5050
ip route 0.0.0.0 0.0.0.0 xxx.xx.xxx.xxx
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
Isaac,
I don't see a statement in your config point port 80 on interface f4 to your web server. Have you put the statement in already? If not do this:
ip nat inside source static tcp (WEBSERVER LAN IP ADDRESS) 80 interface FastEthernet4 80
When you say all the firewalls are configured. How'd you mean? If you mean that there is zone based firewall of access-list based firewall on the router then you need to post the configs for that as well - as it could well be blocking traffic.
Tim
The firewall I meant is the Window Server 2008 R2's firewall which host the web server. I tried typing the syntex you gave me but it didn't work. It says % Invalid input detected at '^' marker which is pointing to ip's P
Thanks in advanced
    Please confirm me that you can connect web server with tcp/5050 in local lan.  What do you do when trying to connect web server with tcp/5050 in the internet? Please post entire confifuration,excluding sensitive information
Toshi
Hi Toshi,
Yes, I can connect the web server through the LAN connection via http://xxx.xxx.x.xx:5050
When trying to connect web server with tcp/5050 in the internet, I type in the public IP address and port 5050 on the browser like http://xxx.xx.xx.xxx:5050
However, it does not response to anything.
Which configuration should I post it to you and please advice on the command as I am new to this.
Thank you.
   Please don't post the exact public ip address. Just modify it. First,we need to see translations on the router first. Please post the entire configuration,excluding sensitive information.
Toshi
Hi Toshi,
which configuration you are referring to here? show ip nat translation and netstat -an?
   "show running"
Toshi
Hi Toshi,
Here is the configuration
ip source-route
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.101 192.168.1.254
ip dhcp pool LAN_POOL
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 192.168.1.1
   domain-name Belkin
ip cef
ip domain name xxx.xxx.xxx
ip name-server xxx.xxx.xxx.xxx
no ipv6 cef
license udi pid CISCO881-K9 sn FHK143874UW
username xxx privilege 15 secret 5 $1$YSYH$cq4FYQv9RTXbF2dKPQBWy1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
description 00062299sng$ES_WAN$
ip address xxx.xxx.xxx.xxx 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex full
speed 100
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address xxx.xxx.xxx.xxx 255.255.255.240 secondary
ip nat inside
ip tcp adjust-mss 1452
ip http server
ip dns server
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx
no cdp run
The IP NAT has already open port 5050 to the web server however it is still not working.
  Is there any Firewall in between the router and your local lan?  Please post the output of "show ip nat translation" while connecting that web server with TCP/5050 from the internet. Windows Server Right? Please post the output of  "netstat -an"  on webserver while connecting that web server with TCP/5050 from the internet.
Toshi
