Cisco NAT type
Leshkan
Community Member
Good day to everyone!
Could someone tell me what type of NAT Cisco implements?
As far as I know there are 4 types of NAT: Symmetric, Full Cone, Address Restricted, Port Restricted.
To be more precise:
I have Cisco 881 router with overloaded NAT and no ACL on external interface.
Supposing that some host from internal network has connected to external host, and the router created translation: internal host address iAddr:iPort is mapped to router's external address eAddr:ePort:
Which packets will router accept?
1) Packets from any external host destined to eAddr:ePort
2) Packets from the external host to which the internal one was previously connected, destined to eAddr: any port
3) Packets from the external host to which the internal one was previously connected, destined to eAddr: ePort
Thanks in advance!
Best regards,
dbeattie
Level 7
Level 7
Hi Leshkan,
Cisco Overload NAT is a dynamic NAT also known as Hide NAT. This means that it is functionally an outbound NAT with source port translation, so the only packets from external hosts that will get forwarded to the internal host are packets that are considered to be replies. In a relatively simple device like your 881, this will be a reply defined at layer 4. If you were to run an IOS firewall on the device, this gets extended to layer 7 replies, allowing protocols like FTP to work properly. This aligns to your option 3.
Hope this helps
Dave
Leshkan
Community Member
One more precision:
If the internal host has initiated connection to external host and NAT translation still exists on the router, will that external host be able to initiate connection to the internal host, and in what circumstances?
I mean: will the router accept new packets from that external host?
Best regards,
In theory no further packets should be allowed when the session ends because the dynamic NAT entry should be removed from the NAT table. In practice this may be HW & SW dependent. Some may keep the NAT entry in the table until an idle timeout occurs. Certainly if you run the IOS firewall, the entry should be marked as closed, preventing further traffic, but left in the table for a period of time in order to prevent re-use.
Hope this helps
Dave
