ISR 4300 Management Interface Input Drops
j.a.m.e.s
Level 4
Level 4
Dear All,
Could anyone point me in the right direction to troubleshoot input drops on my ISR4331 Gi0 interface please? The drops are constantly incrementing and the interface stops responding to ping/ssh/snmp after around 1 or 2 hours. A shut/no shut makes it responsive for another while.
I have swapped the cable (it's a 2m cat6 to a nearby Nexus 2k FEX), tried auto neg, removed any access-policies on the line vty. The code version is 16.03.07, but I can't find any bugs. Packet capture is also not supported on the management interface.
4431#sho run inter gi0
interface GigabitEthernet0
 description OOB-FEX Eth109/1/6 VL806
 vrf forwarding Mgmt-intf
 ip address 10.0.0.1 255.255.255.192
 no ip redirects
 no ip unreachables
 speed 1000
 no negotiation auto
end
Here are the errors:
4431#show inter gi0
GigabitEthernet0 is up, line protocol is up
  Hardware is RP management port, address is 4001.7a35.c85f (bia 4001.7a35.c85f)
  Description: GESOOBML03 Eth109/1/6 VL806
  Internet address is 10.238.203.52/26
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 254/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Full Duplex, 1000Mbps, link type is force-up, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:03, output 00:00:05, output hang never
  Input queue: 0/75/6156/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 2 packets/sec
     442568 packets input, 51132110 bytes, 0 no buffer
     Received 1735 broadcasts (0 IP multicasts)
     6156 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     19497 packets output, 4748654 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
This also doesn't shed much light:
chges-d-svuvu-01#sho inter gi0 switching
GigabitEthernet0 GESOOBML03 Eth109/1/6 VL806
          Throttle count          0
                   Drops         RP       6165         SP          0
             SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs          0      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process         71       3282       8487     866569
            Cache misses          0          -          -          -
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process       2416     144960       1392      83520
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process       3073     875805       6900    3026964
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          0          0      12356    4606910
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    NOTE: all counts are cumulative and reset only after a reload.
Any suggestions would be greatly appreciated.
James.
gaston.benitez
Hi James.
Did you try to set negotiation auto on both sides at the same time?
BR
Gaston
Yes, we tried disabling auto neg at both sides to no avail.
In fact, we recently resolved this issue. I should mention that the upstream device is a Nexus 2k FEX and the HSRP gateway is running on a VPC pair. We noticed this within a debug interface gi0 on the ISR4K:
316292: Dec  3 18:19:31.673 GMT: IOSXE-INJECT: set pak datagramstart(from 0x7sho F77CBFB6B1A to 0x7F77CBFB6B28), datagramsize(from 98 to 84);
316293: Dec  3 18:19:31.674 GMT: IOSXE-INJECT: add L3 inject hdr
316300: Dec  3 18:19:31.678 GMT: IOSXE-INJECT: ARP/ND trigger failed, id 0x1, linktype ip, type incomplete, nexthop defined, reason adj not found
316301: Dec  3 18:19:31.678 GMT: IOSXE-INJECT: simulate cpp forward drop failed packet,: triggering arp/nd, v4 10.238.203.62, adj-id 0x0, intf Gi0 Output intf Gi0 matches debug filer
It looks like the ISR was failing to make an ARP request for the default gateway.
So I added a static entry corresponding to the virtual mac on the HSRP GW:
arp vrf Mgmt-intf 10.0.0.1 0000.0c9f.f001 ARPA
This worked around the issue of the interface going unresponsive every few hours.
We then upgraded from Denali to Everest (without upgrading ROMMON or the CPLD) and removed the static arp entry. The issue has gone away, including all the input errors.
My conclusion from all this is that there's an undocumented bug in Denali which prevents the Gi0 interface from working with Nexus HSRP.
