12-27-2024 09:22 AM
Can anyone assist? Trying to connect Calix DSLAM directly to router using Calix 100G, 40k BiDi optics. In all scenarios with NCS 55A1 routers, optics function as expected. With our new site, host is an NCS57B1, will not transmit light.
NCS 57B1 with Calix 40k BiDi. Same optic working in NCS 55A1.
Not transmitting light.
Fri Dec 27 10:35:27.262 CST
QSFP8636 EEPROM port: 16Xcvr Type: QSFP28Ext Type: 3.5W, CLEI, TX CDR, RX CDR, 4.0W, Connector Type: LCEthernet Compliance Codes: SONET Compliance codes: SAS/SATA compliance codes: Gigabit Ethernet Compliant codes: Encoding: 64B66B, BR, nominal: 25500 Mbps
Length SMF: 40KM, OM3: 0M, OM2: 0M, OM1: 0M, Cable: 0MDeice Tech: 1310nm EML, Active WL Control, Cooled Transmitter, APD Detector, Vendor Name: DATALIGHT Vendor OUI: 00.00.00
Vendor Part Number: 100-05912-BXU-SL (rev.: 01)Wavelength: 1304.550 nmWavelength Tolerance: 1.000 nmVendor Serial Number: DLOAX1000196 Date Code (yy/mm/dd): 24/05/14 lot code: Diagnostic Monitoring Type: RX Avg, TX, Enhanced Options: Init Complete Flag Impl, Extended Module Codes: EDR, Options: L-Tx/Rx LOS: L-Tx Fault: L-Tx/Rx LOL: RX1, Module DDM:
MSA Data (Lower Memory)0x0000: 11 08 00 00 00 01 00 00 : 00 00 00 50 00 50 00 00 0x0010: 00 00 00 00 00 00 1c 6d : 00 00 81 d0 00 00 00 00 0x0020: 00 00 01 f9 01 f9 01 f9 : 01 f9 00 00 00 00 00 00 0x0030: 00 00 00 01 00 01 00 01 : 00 01 00 00 00 00 00 00 0x0040: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00 0x0050: 00 00 00 00 00 00 0f 00 : 00 00 00 00 00 05 00 00 0x0060: 00 00 00 00 00 00 00 00 : 00 00 00 2d 00 00 10 00 0x0070: 00 00 00 00 2e 00 00 00 : 00 00 00 00 00 00 00 00
MSA Data (Upper Memory Page 00)0x0080: 11 fd 07 80 00 00 00 00 : 00 00 00 05 ff 00 28 00 0x0090: 00 00 00 6e 44 41 54 41 : 4c 49 47 48 54 20 20 20 0x00a0: 20 20 20 20 10 00 00 00 : 31 30 30 2d 30 35 39 31 0x00b0: 32 2d 42 58 55 2d 53 4c : 30 31 65 eb 00 c8 55 26 0x00c0: 2e 7f 3f d5 44 4c 4f 41 : 58 31 30 30 30 31 39 36 0x00d0: 20 20 20 20 32 34 30 35 : 31 34 20 20 3c 11 67 e9 0x00e0: 43 61 6c 69 78 20 43 65 : 72 74 69 66 69 65 64 52 0x00f0: 42 56 4c 33 42 44 35 46 : 41 41 00 00 00 00 00 00 CLEI Code: Calix CertPart Number: ifiedCBVL3 (ver.: BD5F)Product Id:
MSA Data (Upper Memory Page 02)0x0180: 43 61 6c 69 78 20 43 65 : 72 74 69 66 69 65 64 43 0x0190: 42 56 4c 33 42 44 35 46 : 41 41 30 35 39 31 32 79 0x01a0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00 0x01b0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00 0x01c0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00 0x01d0: 00 00 00 00 20 20 20 20 : 20 20 00 00 00 00 00 00 0x01e0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00 0x01f0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
ModuleThresholds: Alarm High Warning High Warning Low Alarm LowTemperature: +88.000 C +86.000 C -42.000 C -45.000 CVoltage: 3.630 Volt 3.465 Volt 3.135 Volt 2.970 Volt
LanesThresholds: Alarm High Warning High Warning Low Alarm LowBias: 120.000 mAmps 116.000 mAmps 14.000 mAmps 10.000 mAmpsTransmit Power: 6.55200 mW (8.16374 dBm) 6.44960 mW (8.09533 dBm) 1.41280 mW (1.50081 dBm) 0.89120 mW (-0.50025 dBm)Receive Power: 0.57600 mW (-2.39578 dBm) 0.45760 mW (-3.39514 dBm) 0.02400 mW (-16.19789 dBm) 0.01200 mW (-19.20819 dBm)
Temperature: +28.425 CVoltage: 3.315 Volt
TxRxIOMagId:
RxOpAmpSupprt:
Lane Temp Bias Tx Power Rx Power
0 N/A 0.000 mAmps 0.000 mW (<-40.00 dBm) 0.05050 mW (-12.96709 dBm)
1 N/A 0.000 mAmps 0.000 mW (<-40.00 dBm) 0.05050 mW (-12.96709 dBm)
2 N/A 0.000 mAmps 0.000 mW (<-40.00 dBm) 0.05050 mW (-12.96709 dBm)
3 N/A 0.000 mAmps 0.000 mW (<-40.00 dBm) 0.05050 mW (-12.96709 dBm)
MSA Data (Upper Memory Page 03)0x0200: 58 00 d3 00 56 00 d6 00 : 00 00 00 00 00 00 00 00 0x0210: 8d cc 74 04 87 5a 7a 76 : 00 00 00 00 00 00 00 00 0x0220: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00 0x0230: 16 80 00 78 11 e0 00 f0 : ea 60 13 88 e2 90 1b 58 0x0240: ff f0 22 d0 fb f0 37 30 : 00 00 00 00 00 00 00 00 0x0250: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00 0x0260: 77 1f 00 c8 0f 01 00 00 : 00 00 33 33 22 22 11 11 0x0270: 00 f0 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
12-27-2024 02:17 PM
-3rd party optic is never guaranteed to work, even if it does on another cisco device ,
checkout : https://tmgmatrix.cisco.com/?npid=4364 'to be good'
- You may try to check the logs when the connection is made , use recent software on the NCS, or
use commands as in :
(config)# no errdisable detect cause gbic-invalid
(config)# service unsupported-transceiver
If available ,
M.
12-27-2024 06:05 PM
Use an LC-LC loopback plug and see if the link goes up or goes into error-disable.
