Cisco newbie - can't seem to get default GW working
Ghostbear_G
I am trying to practice for my CCNA, and i picked up an old Cisco 1921 Router (and Catalyst Switch) just to get some practice making my own network. I set everything up to use ROAS, but I can't ping out to the internet (8.8.8.8). I can ping all the connected devices, but it looks like for some reason i cannot find, my Gateway of last resort is not set, and i can't figure out why for the life of me. Ill post my run config below if anyone's willing to look it over and help me figure out what's wrong.
Spoiler
GatewayRouter#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
S* 0.0.0.0/0 [0/0] via 0.0.0.0, GigabitEthernet0/0
10.0.0.0/8 is variably subnetted, 7 subnets, 2 masks
C 10.0.0.1/32 is directly connected, Loopback0
C 10.0.1.0/24 is directly connected, GigabitEthernet0/1.1
L 10.0.1.1/32 is directly connected, GigabitEthernet0/1.1
C 10.1.1.0/24 is directly connected, GigabitEthernet0/1.10
L 10.1.1.1/32 is directly connected, GigabitEthernet0/1.10
C 10.1.2.0/24 is directly connected, GigabitEthernet0/1.20
L 10.1.2.1/32 is directly connected, GigabitEthernet0/1.20
* 192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C* 192.168.0.0/24 is directly connected, GigabitEthernet0/0
L 192.168.0.106/32 is directly connected, GigabitEthernet0/0
GatewayRouter#sh run
Building configuration...
Current configuration : 3026 bytes
! Last configuration change at 02:39:24 UTC Wed Mar 31 2021 by nick
! NVRAM config last updated at 01:18:34 UTC Wed Mar 24 2021
version 15.1
hostname GatewayRouter
boot-start-marker
boot-end-marker
enable secret 4 TkhWb9iRSIgxflbwpcOX0UCPFnZJFHZBfQ/LFoGNOcQ
enable password bohr
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.1.1.1
ip dhcp excluded-address 10.1.1.2
ip dhcp excluded-address 10.1.1.3
ip dhcp excluded-address 10.1.1.4
ip dhcp excluded-address 10.1.1.5
ip dhcp excluded-address 10.1.1.6
ip dhcp excluded-address 10.1.1.7
ip dhcp excluded-address 10.1.1.8
ip dhcp excluded-address 10.1.1.9
ip dhcp excluded-address 10.1.1.10
ip dhcp excluded-address 10.1.2.1
ip dhcp excluded-address 10.1.2.0
ip dhcp excluded-address 10.0.1.1
ip dhcp pool LAN DHCP
network 10.1.1.0 255.255.255.0
dns-server 8.8.8.8 8.8.4.4
domain-name bohr.com
default-router 10.1.1.1
ip dhcp pool Wireless LAN
network 10.1.2.0 255.255.255.0
default-router 10.1.2.1
ip dhcp pool MGMT DHCP
network 10.0.1.0 255.255.255.0
dns-server 52.119.45.76 8.8.8.8 8.8.4.4
default-router 10.0.1.1
ip domain name bohr.com
license udi pid CISCO1921/K9 sn FGL17042147
username nick password 0 bohr
ip ssh version 2
interface Loopback0
ip address 10.0.0.1 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Uplink-to-modem
ip address dhcp
duplex auto
speed auto
interface GigabitEthernet0/1
description LAN
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
description mgmt VLAN
encapsulation dot1Q 1 native
ip address 10.0.1.1 255.255.255.0
interface GigabitEthernet0/1.10
description LAN VLAN
encapsulation dot1Q 10
ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet0/1.20
description Wireless VLAN
encapsulation dot1Q 20
ip address 10.1.2.1 255.255.255.0
router ospf 1
network 10.0.0.0 0.0.255.255 area 0
network 10.1.0.0 0.0.255.255 area 0
network 192.168.0.0 0.0.255.255 area 0
default-information originate
router rip
version 2
network 10.0.0.0
network 192.168.0.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip default-network 192.168.0.0
ip route 0.0.0.0 0.0.0.0 192.169.0.1
11 Replies 11
it looks like you are missing the NAT part. Use the simplified configuration below (important parts marked in bold):
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip ssh version 2
interface Loopback0
no ip address
shutdown
ip address dhcp
--> ip nat outside
duplex auto
speed auto
description LAN
no ip address
duplex auto
speed auto
--> ip nat inside
--> ip nat inside
--> ip nat inside
--> ip nat inside source list 1 interface GigabitEthernet0/0
no ip http server
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
--> access-list 1 permit 10.0.0.0 0.0.0.255
@ Georg Pauwen , bit of typo
no access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.0.0.0 0.0.7.255
Kind Regards
Paul
No typo. I used that access list on purpose, in case any other Vlans in the 10.0.0.0/8 range are added.
will work just fine.
will work just fine
Unfortunately it won’t -the original acl range is a /24 bit subnet not a /16 , the OP have at least 3 subnets that require nat
Kind Regards
Paul
Paul,
ouch. I see, my bad. You are right.
What I meant was:
access-list 1 permit 10.0.0.0 0.255.255.255
That would cover everything in the 10.0.0.0/8 range, even if additional subnets are added...
Ghostbear_G
hey guys. thank you very much for the assistance. I tried to implement the fixes mentioned above, (see spoiler) and it added a few lines automatically like the overload on the ip nat source and the 'ip virtual-reassembly in' line. Unfortunately it does not seem to have resolved my issue:
GatewayRouter#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
GatewayRouter#ping 8.8.8.8 source 10.1.1.1
Packet sent with a source address of 10.1.1.1
I tried adding the 'permit any' to access-list 1 after there was no success just to make sure nothing was getting blocked, but no joy.
Are there any other suggestions for commands I'm missing, or could the router itself just be borked?
Spoiler
Current configuration : 3366 bytes
! Last configuration change at 00:52:24 UTC Thu Apr 1 2021
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip ssh version 2
interface Loopback0
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
description LAN
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
router ospf 1
router rip
version 2
network 10.0.0.0
network 192.168.0.0
no ip http server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit any
Hello
You should be able to ping the internet from the router if you cannot then something else is wrong -However Please remove and add the following
no ip default-network 192.168.0.0
no ip route 0.0.0.0 0.0.0.0 192.169.0.1
no router rip
no router ospf
no int loopback 0
no access-list 1
no ip dhcp excluded-address 10.1.2.0
access-list 1 permit 10.0 1.0 0.0.255
access-list 1 permit 10.1.1.0 0.0.255
access-list 1 permit 10.1.2.0 0.0.255
lastly make sure the connection on the switch that connects to this rtr gig0/1 interface is a trunk interface and you have created the additional l2 vlans  10-20
Post the output from:
sh ip int brief
sh arp
Kind Regards
Paul
what you have posted in the spoiler looks very different from what was originally proposed. Make sure when you issue a 'sh run', everyting looks exactly like below. Just go through this line by line, and remove everything that does not match.
That said, is the LED on GigabitEthernet0/0 lit green ? Also, what else is in your network (why do you have OSPF and RIP configured) ?
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip ssh version 2
interface Loopback0
no ip address
shutdown
ip address dhcp
--> ip nat outside
duplex auto
speed auto
description LAN
no ip address
duplex auto
speed auto
--> ip nat inside
--> ip nat inside
--> ip nat inside
no ip http server
--> access-list 1 permit 10.0.0.0 0.255.255.255
Ghostbear_G
Thanks for all the help again.  I added the routing protocols under the vain hope they would populate my Gateway of last resort (clearly they did not). The ports lights are green on the router, and the Switch has all the VLANS configured, with the uplink port set for trunk and allowing all Vlans. I have tried to match the suggested commands as much as possible, but the router is adding lines without my input, for example the overload command on the below command. I have removed it and re-added it a few times, and the router always overloads it.
GatewayRouter#sh ip int brief
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 192.168.0.106 YES DHCP up up
GigabitEthernet0/1 unassigned YES manual up up
GigabitEthernet0/1.1 10.0.1.1 YES manual up up
GigabitEthernet0/1.10 10.1.1.1 YES manual up up
GigabitEthernet0/1.20 10.1.2.1 YES manual up up
Loopback0 10.0.0.1 YES manual up up
NVI0 192.168.0.106 YES unset up up
GatewayRouter#sh arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 8.8.4.4 0 Incomplete ARPA
Internet 8.8.8.8 0 Incomplete ARPA
Internet 10.0.1.1 - acf2.c581.bb41 ARPA GigabitEthernet0/1.1
Internet 10.1.1.1 - acf2.c581.bb41 ARPA GigabitEthernet0/1.10
Internet 10.1.1.13 0 4ccc.6a8a.638e ARPA GigabitEthernet0/1.10
Internet 10.1.2.1 - acf2.c581.bb41 ARPA GigabitEthernet0/1.20
Internet 10.5.0.10 0 Incomplete ARPA
Internet 10.5.0.12 0 Incomplete ARPA
Internet 10.5.0.44 0 Incomplete ARPA
Internet 192.168.0.1 0 60e3.275d.f2df ARPA GigabitEthernet0/0
Internet 192.168.0.106 - acf2.c581.bb40 ARPA GigabitEthernet0/0
Internet 192.168.0.107 0 d8d0.9004.1974 ARPA GigabitEthernet0/0
Internet 192.168.0.108 14 4ccc.6a8a.638e ARPA GigabitEthernet0/0
I have no idea where the 10.5.x.x IPs are coming from, i never added them.
C 192.168.0.0/24 is directly connected, GigabitEthernet0/0
GatewayRouter#sh ip route 8.8.8.8
% Network not in table
From my understanding, if the IP is not in the route table, the router should direct it out the Gateway of Last Resort automatically, which is why I am concerned/confused about the lack of a GW on the router., and why I had several attempted commands to add a GW.
Spoiler
Current configuration : 3264 bytes
! Last configuration change at 03:15:17 UTC Fri Apr 2 2021
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip ssh version 2
interface Loopback0
no ip address
shutdown
ip address dhcp
ip nat outside
no ip virtual-reassembly in
duplex auto
speed auto
description LAN
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
router ospf 1
no ip http server
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.1.2.0 0.0.0.255
control-plane
Hello
The root cause is your isp modem, you seem to obtaining an ip address however you cannot reach the internet, now the question is:
Before you attached this cisco rtr did you have just a pc or another device connected to the isp modem and did it work?
if the answer is yes. Then its possible the modem is negating internet access due to the untrusted arp address (cisco rtr) it is now seeing.
To bypass this you can "Spoof" the moden by setting the arp of the "old" device that worked on the cisco gig0/0 infterface.
cisco rtr
int gig0/0
mac-address xxxx.xxxx.xxxx < old pc mac address>
Kind Regards
Paul
I agree with Paul, the ISP modem appears to be an issue. What brand/type/model is the modem, and who is your ISP ?
