Cisco Packet Trace route problem
Translator
Community Manager
Community Manager
I'm new to network administration and currently licensed.
I have a problem with my static routes, I can't ping my router0 with the IT PC.
If I do a show ip config nothing appears on my switch core... I don't understand why, if I have already added routes (you can see them by doing a show run).
The PKT is attached.
Thank you very much for your help.
on the switch, enable 'ip routing':
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#ip routing
Switch(config)#end
Switch#conf t
Switch(config)#end
Thank you very much it works! I forgot to activate this on the switch!
