Cisco Packet Tracer Business Topology Diagram
what are you running into, where are you getting stuck ? If you have a Packet Tracer project file, post it here (ZIP it first)...
I could not make topology diagram according the basic requirements .
I put together a network that should get you started (zipped project file attached, saved in Packet Tracer version 8).
The routers serve as DHCP servers and dish out only half of the addresses available. Each router is running OSPF, and a floating static route with an administrative distance of 111 (higher than OSPF) in order to make it a backup route.
