Cisco PPP dialer not working
lakhwaraa
interface Dialer1
mtu 1480
bandwidth 6000
ip address negotiated
ip nat outside
ip virtual-reassembly in
zone-member security outside
encapsulation ppp
ip tcp adjust-mss 1400
dialer pool 2
dialer-group 2
ppp authentication chap pap callin
ppp chap hostname sakkhro
ppp chap password 0 7766
ppp pap sent-username sakkhro password 0 7766
no cdp enable
Sh ip int brief
Interface      IP-Address         OK?             Method       Status         Prot
Dialer1          unassigned         YES          NVRAM          up             up
I am unable to get ip address while dialing through cisco router. My username password is working as i have checked on windows. what is the problem.
balaji.bandi
Why are you using both PAP and CHAP username and password to send ? what did that worked in windows so use same method.
here is the standard config that should work :
interface Ethernet0/0/0
no ip address
interface Ethernet0/0/0.101   (if the ISP lookingDot1.q)
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
description ISP DSL
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication pap chap ms-chap callin
ppp chap hostname <REMOVED>
ppp chap password 0 <REMOVED>
ppp ipcp address accept
no cdp enable
still not working
post show run (complete config)
also run debug :
debug ppp negotiation
debug ppp authentication
Troubleshooting guide :
https://www.cisco.com/c/en/us/support/docs/long-reach-ethernet-lre-digital-subscriber-line-xdsl/asymmetric-digital-subscriber-line-adsl/71124-adslguide-pppoedsl-ts.html
BB
Now the method has changed from automatic to manual
Interface        IP-Address           OK?              Method              Status          Protocol
Dialer1           unassigned          YES                manual             up                 up
also i cant use debug as i dont have access to physical router. only ssh
from SSH you can do debug - issue terminal monitor and run the debug
BB
friend I write in your other post, please share the Zone config I think there is soemthing in Zone security config.
