cisco route 0.0.0.0 from specific source (PBR)
shlomoi
We recently added another internet port to our network, I would like to pass through this port only a specific
vlan
The
vlan is 192.168.1.1/24
which will go through
10.10.2.1
At the moment the routing of all our networks is through the FW.
And I want only the
192.168.1.1
network to exit through the new line in the address
10.10.2.1
The equipment is connected to the
nexus 9k
Can someone help with PBR in
Nexus
3 Accepted Solutions
M02@rt37
Hello @shlomoi,
Since you want to do PBR with
n9k
check documentation here:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/unicast/configuration/guide/l3_cli_nxos/l3pbr.html
-Enable feature
--Create ACL that match subnet 192.168.1.0/24:
access-list XX permit 192.168.1.0 0.0.0.255
--Create route map that match your acl and set the desired next-gop:
route-map My-PBR permit 5
match address XX
set ip next-hop 10.10.2.1
Best regards
Giuseppe Larosa
Hello @shlomoi ,
is the Nexus acting as L3 device ?
if the
subnet 192.168.1.0
is directly connected PBR has to be applied to the SVI vlan interface (L3 gateway logical interface)
if the
192.168.1.0
is internal and learned via another L3 device you need to apply PBR inbound on the L3 interface that would be used to reach the
192.168.1.0 subnet
You need to define an ACL that matches the
192.168.1.0 subnet
access-list 10 permit 192.168.1.0 0.0.0.255
route-map PBR permit 10
match address 10
Warning : being a Nexus you may need to enable a feature before you can use PBR
Edit:
you need
feature pbr
see the link provided by M02@rt37
Hope to help
Giuseppe
The command to associate PBR with the port is
ip policy <route-map-name>
applied in interface config  mode.
Rick
6 Replies 6
Hi @shlomoi
 Any reason for you to use PBR? Cause this can be achieved with the following command
ip route 192.168.1.1/24  10.10.2.1
M02@rt37
Hello @shlomoi,
n9k
-Enable feature
match address XX
Best regards
Giuseppe Larosa
Hello @shlomoi ,
if the
subnet 192.168.1.0
if the
192.168.1.0
192.168.1.0 subnet
192.168.1.0 subnet
match address 10
Edit:
you need
feature pbr
Hope to help
Giuseppe
The network
192.168.1.1
arrives in OSPF to the Nexus and from there it should go out
via 10.10.2.1
The port in Nexus is interface
Ethernet1/43
What is the command to associate the PBR with the port
Thank you
Rick
I am glad that our suggestions have been helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
