help with router 1841 configuration
yossryhelal
I am trying to practice for the CCNA but I got issue with the cisco 1841 router config, So the issue is I connected I have f0/0 and f0/1 as dhcp but I see only f0/0 show assigned to ip address and up but f0/1 connected to my laptop but still shows unassigned, and NVI0 has ip address as well and up  any idea how I can make f0/1 to show assigned as f0/0 and be able to connect it to my lap as hardwire conneted ethernet??
Thank you!
5 Replies 5
identit255
So... Could you send full conf? Just the output of sh run command.
yossryhelal
interface FastEthernet0/0
ip address dhcp
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
ip address 20.20.20.3 255.255.255.0
ip forward-protocol nd
no ip http server
control-plane
disable-eadi
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
R3#
These two following actions should fix your problem, if i have clearly understood your problem:
1) Both your interfaces (f0/0 and f0/1) are in a shutdown state, you have to turn them on by executing no shutdown command.
2) You have to apply ip address dhcp command on interface f0/1to get a ip address.
Hope this help.
identit255
Plus as I see the dhcp server is not configured locally, so you have to set dhcp relay ip address.
M02@rt37
Hello @yossryhelal,
What do you want to do?
Connect PC on fa 0/0 and fa 0/1 and deliver IP address to that PCs ?
If yes! Give an IP add. to these interfaces as Gateway of PCs and configure DHCP server on 1841 to deliver IP add to PCs.
If no! Please more elaborate.
Thanks.
Best regards
