cisco router 1117 not able to boot properly
kdsingh007
Hi, what could be the reason ?
Last reset cause: Unrecoverable Error
C1117-4PWA platform with 4194304 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Located pnp-tech-time
Unsupported package header version (-1347440721)
Located pnp-tech-discovery-summary
Unsupported package header version (542463043)
Located vlan.dat
Unsupported package header version (0)
Located memleak.tcl
Unsupported package header version (540160049)
Located throughput_monitor_params
Located c1100-universalk9_ias.16.12.05.SPA.bin
Package header rev 3 structure detected
IsoSize = 500219904
Performing Integrity Check ...
Performing Signature Verification ...
RSA Signed RELEASE Image Signature Verification Successful
Image validated
PHY reset timed out
Rom image verified correctly
System Bootstrap, Version 17.6.1, RELEASE SOFTWARE
Copyright (c) 1994-2021 by cisco Systems, Inc.
Current image running: Boot ROM0
8 Replies 8
balaji.bandi
Looks like the version image you trying may be lower i guess
Try any image 17.X version and post complete boot Logs for us to understand.
BB
question
I have other 1117 routers with System Bootstrap, Version 17.6.1 and xe c1100-universalk9_ias.16.12.05.SPA.bin and all working fine and rebooting properly. what could go wrong for this specific one?
Good that you told me same working as expecting, this makes me thing this router may be bad
Can you please connect the console post all the boot logs right from Router boot up to until fail
BB
i am connected to it as Out of band US robotics modem which is connected to the console port of the router and see only below again and again:
Located vlan.dat
Located memleak.tcl
IsoSize = 500219904
Image validated
PHY reset timed out
To be honest with that messages its hard to tell what went wrong.
Quick way you can try is - any new IOS XE 17.6.X would fix the issue (that what i think) - if you get chance please try that and let me know.
BB
i have followed this compatibility matrix @
https://www.cisco.com/c/en/us/td/docs/routers/access/1100/release/17-6/isr1k-rel-notes-xe-17-6-x.html#concept_qgk_1cf_tmb
Cisco ISR1000 ROMMON Compatibility Matrix
The following table lists the ROMmon releases supported in Cisco IOS XE 16.x.x releases and Cisco IOS XE 17.x.x releases
Table 3. Minimum and Recommended ROMmon Releases Supported on Cisco 1000 Series Integrated Services RoutersCisco IOS XE ReleaseMinimum ROMmon Release Supported for IOS XERecommended ROMmon Release Supported for IOS XE
16.6.x
16.6(1r)
16.6(1r)
16.7.x
16.6(1r)
16.6(1r)
16.8.x
16.8(1r)
16.8(1r)
16.9.x
16.9(1r)
16.9(1r)
16.10.x
16.9(1r)
16.9(1r)
16.11.x
16.9(1r)
16.9(1r)
16.12.x
16.9(1r)
16.12(1r)
17.2.x
16.9(1r)
16.12(1r)
17.3.x
16.12(2r)
16.12(2r)
17.4.x
16.12(2r)
16.12(2r)
17.5.x
17.5(1r)
17.5(1r)
17.6.x
17.5(1r)
17.5(1r)
Leo Laohoo
If the router has boot into ROMMON, post the complete output to the command "set".
Do not edit out anything, especially the serial number of the router.
I suspect one of two things:
1.  The router config-registry is not 0x2101 or 0x2102.
2.  A new-ish hardware revision number which means it needs to boot a more later version.
EDDY MULDER
What i dont understand that during booting an ios and performing the IOS validation you are not getting a warning stating that the current rommon is outdated / not supported ... This caused me a lot of time finding the cause why a certain ios version was not able to boot up after upgrade ... .
During reload the rommon doesnt get upgraded automaticly, i had to download 1st a version where the new rommon was required , which then performed the rommon upgrade before the actual required ios could be loaded.
Looks to me a simple check to implement during ios boot process and not taking to much resources
