Cisco router 1801 and WebVPN
effeggi561
Hi to all,
I'm a novice in Cisco hardware. I'm evaluating the 1801 model, but I'm not sure it supports clientless VPN (ssl). if so, I'd also like to know how many web tunnels does it support, and if it's possible to browse the internet (with the "router" inet link or with the client inet link) once connected in ssl vpn.
thank you in advance
6 Replies 6
thank you for the reply...
unfortunately I still have the same doubts regarding WebVPN availability on 1801, since it is not written in the document, but the some posts seems to report users with 1801 and ssl vpn ...
any other can help me ?
thanks!
fabiengermain
You don't need to install any specific client, it's embedded in the https portal (ActiveX or Java). And yes you can browse the Internet through the SSL VPN (anounce a new default route), or juste choose to announce your LAN.
Does it answer your questions ?
Yes, thank you!
How many tunnels does it support simultaneously?
Have a look here : http://www.cisco.com/en/US/products/ps6657/prod_bulletin0900aecd80501bb7.html
Cisco 1811 (and 180x) -> max 10 users.
thank you
