Cisco Router 1841 can't boot
soksamrong.vann
Hey. Guys my router 1841 have issue can't boot ios, so can you give me for the solution to fix it?
5 Replies 5
Leo Laohoo
Please elaborate what you mean by this?
No display on the console?
Router goes into ROMmon?
Router doesn't power up?
Please my report issue
*Oct  4 04:18:14.511: %SYS-5-RELOAD: Reload requested  by console. Reload Reason: R        eload Command.c1841 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initializedþ
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Correcting the backup nv_flash
PLD version 0x10
GIO ASIC version 0x127
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x1d51190
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
PLD version 0x10
PLD version 0x10
*** TLB (Store) Exception ***
Access address = 0x27100
PC = 0xbfc24b00, Cause = 0x800c, Status Reg = 0x30410002
rommon 1 >
Three suspects:
1.  There is no CF media present;
2.  The CF is a third-party non-supported variety;
3.  CF port is faulty
how to solved it? can give me step by step!
Seriously?
I've already provided THREE (3) possible reasons why the router has rebooted into ROMmon.
Which of the three is not clear?
