Cisco Router 1941 K9 NAT,PAT and RDP port forwarding
Dear,
I have one cisco router (Model : 1941/K9). I want to configure the following settings in this router. please give me complete configuration step by step. It will be a great favour to me.
Local IP : 192.168.10.52   RDP Port number : 3389
  192.168.10.52   Weblogic Port number : 7001
Public IP : 84.87.120.223
i want to connect to my local IPs through public IP. For example, from outside if i give 84.87.120.223:3389 in remote desktop connection then it should connect to 192.168.10.52:3389 and if i enter 84.87.120.223:7001 in web browser then it should connect to 192.168.10.52:7001.
Please help me!!!
Thank You!
Best Regards,
Sammy.
10 Replies 10
Pawan Raut
Level 4
Level 4
Configured ip nat inside on LAN interface connected router.
Configure ip nat outside on ISP connected router interface having Public IP subnet.
Configure Port forwarding as per requirement
ip nat inside source static tcp 192.168.10.52 3389 84.87.120.223 3389
ip nat inside source static tcp 192.168.10.52 7001. 84.87.120.223 7001
Kindly rate for useful post
Dear Pawan,
Thank you very much for your reply.
Please check my running-config file below
TPRouter#show running-config
Building configuration...
Current configuration : 2559 bytes
! Last configuration change at 05:02:11 UTC Tue Nov 8 2016
version 15.2
hostname TPRouter
boot-start-marker
boot-end-marker
enable secret 4 yWnkPLHDYkl1Ah.ZPRnHi5MwJ.h5wEG9bClzy3yaDNQ
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FCZ17379195
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.10.250 255.255.255.0
 ip access-group 101 in
 ip nat inside
 ip virtual-reassembly in
 user-group default tp
 duplex auto
 speed auto
 pppoe enable group global
interface GigabitEthernet0/1
 ip address 84.87.120.223 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 192.168.10.52 3389 84.87.120.223 3389 extendable
ip nat inside source static tcp 192.168.10.52 7001 84.87.120.223 7001 extendable
ip route 0.0.0.0 0.0.0.0 84.87.120.222 3
ip route 192.168.10.0 255.255.255.0 192.168.10.251
access-list 1 permit 192.168.10.52
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 101 deny ip host 192.168.10.51 host 66.220.158.68
access-list 101 permit ip any any
control-plane
banner motd ^C-----------This is a secure site. Only authorized users are allowed. For access, contact your IT Administrator-----------^C
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 2
transport input all
line vty 3 4
 login
 transport input all
scheduler allocate 20000 1000
end
Still i am unable to connect through RDP and Web Browser.
can you share sh ip nat translation output
Dear Pawan,
Below is the output of ip nat trans
Pro Inside global      Inside local       Outside local      Outside global
tcp 84.87.120.223:555  192.168.10.52:3389 37.104.229.20:52245 37.104.229.20:52245
tcp 84.87.120.223:555  192.168.10.52:3389 ---               ---
tcp 84.87.120.223:7001 192.168.10.52:7001 37.104.229.20:50340 37.104.229.20:50340
tcp 84.87.120.223:7001 192.168.10.52:7001 37.104.229.20:50341 37.104.229.20:50341
tcp 84.87.120.223:7001 192.168.10.52:7001 ---               ---
My requirement is as follows:
RDP --> 84.87.120.223:555  should connect 192.168.10.52:3389
Web Browser --> 84.87.120.223:7001 should connect 192.168.10.52:7001
As per output nat translation looks correct.
then why i couldn't connect through RDP and web browser
in ip nat trans it is translating but not opening through RDP and web browser
i checked ping test and telnet also both are working
is there anything we have to do settings in servers.
FYI, there windows 2012 R2 STD servers.
This is the server issue. I dont have much for server level troubleshooting
Hello
@sammy.douglas157 wrote:
Dear Pawan,
 ip nat inside
 duplex auto
 speed auto
 ip nat outside
Pawan is correct with the static pat statements however i do see other possible misconfigurations due to the fact this router looks like its a PPOE client but I dont see any dial pool number on the physical interface to associate with a dialer interface?
I would have expected to see something like the following for a possible working configuration regarding a PPOE client:
no ip route 0.0.0.0 0.0.0.0 84.87.120.222 3
no ip route 192.168.10.0 255.255.255.0 192.168.10.251
no ip nat inside source list 1 interface GigabitEthernet0/1 overload
no access-list 1
ip nat inside source list 1 interface dailer10 overload
no ip address
pppoe-client dial-pool-number 1
interface dailer 10
encapsulation ppp
dialer pool 1
ppp authentication chap1
ppp chap hostname TPRoute
ip nat outside
ip route 0.0.0.0 0.0.0.0 dialer 10  84.87.120.222
Kind Regards
Paul
Sir my local IP is 192.168.210.91 and public IP is 45.64.221.252.Sir I using this command for RDP port forwarding in Cisco router 1900(ip nat inside source static tcp 192.168.210.91 3389 45.64.221.252 3389 expendable). but sir I am not able to access by Remote desktop to other place...pls help me sir
post the full config of your router...
