Cisco Router 2800 Error Details Inside
Lost & Found
Level 2
Level 2
I would like to ask how to troubleshoot this kind of error.
We have 2 site and to routers configured as port channel
1st scenario:
Router B can ping router A but router A can't ping Router B but we can remote all the servers frm Router A to Router B.
some of the application from site B was not working so I reloaded the Router A after that its working properly.
2nd scenario
From Site B to A we have connection we can remote server from A - B vise versa but the problem is we don't have telephone connection from B to A and A to B but like on the first scenario we can ping B- A but not A-B router and also we can remote A - B. then I reload router A again after that its working.
there's a syslog message always show after a few minutes = 2015-03-11 15:41:15 Local7.Warning 10.34.63.254 230: *Mar 11 08:55:30.430: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
2015-03-11 15:41:36 Local7.Warning 10.34.63.254 231: *Mar 11 08:55:51.434: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
2015-03-11 15:41:57 Local7.Warning 10.34.63.254 232: *Mar 11 08:56:12.502: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/K-confg) failed
every minute of the day I receive this messages.
Tried to command show process : CPU
(photo Attached)
How to troubleshoot this error what command should I use to troubleshoot or to test it??
thank you
Arvin R.
6 Replies 6
ciscoraju72
hi Arvin
could you please check service config is enabled or not, i think its enabled in your case, because its trying to autoload the configuration from a network server.
cheers
Raju
voice-card 0
archive
 log config
  hidekeys
How about this?
thanks
How about this?
Please do this:
config t
no service config
end
wr
I would like to ask If that command can't affect our configuration?
thanks
Arvin R
I know, for a fact, this command will not affect MY NETWORK.  I can't make an opinion of other people's network.
To ensure the future with your employer, get a proper change control done.
transferred the commands to my test router but I haven't receive any error unlike the production router.
any idea?
thanks
