Cisco Router 2911 Basic Configuration for Internet Services
lalitbogra
I have Cisco 2911 router and want to do some basic configuration.
1. Setup GE 0/0 for WAN
2. Setup GE 0/1 for LAN
3. Routing to allow LAN for Internet Access
4. DHCP DNS
5. Enable HTTP access
Lan port will be connected further with Sonic Wall and then to Cisco Switch on Single Vlan
I have try to do so commands but even after configuration it doesn't show ip on WAN port . Did no find exact commands to setup the configuration.
Building configuration...
Current configuration : 2043 bytes
! Last configuration change at 14:54:59 UTC Mon Mar 7 2016
! NVRAM config last updated at 14:49:44 UTC Mon Mar 7 2016
version 15.2
hostname delhirou
boot-start-marker
boot-end-marker
enable secret 5 xxx
enable password xxx
no aaa new-model
memory-size iomem 25
no ipv6 cef
ip dhcp excluded-address 192.168.1.1 192.168.1.60
ip dhcp pool internet-pool
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 domain-name cimmyt.com
no ip domain lookup
ip name-server 121.242.190.181
ip name-server 121.242.190.210
ip cef
license udi pid CISCO2911/K9 sn FCZ194360LC
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 111.93.125.178 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip nat inside
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip default-gateway 111.93.125.177
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 7 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 111.93.125.177
access-list 7 permit 192.168.1.0 0.0.0.255
snmp-server community public RO
snmp-server enable traps entity-sensor threshold
tftp-server flash0:c2900-universalk9-mz.SPA.155-1.T2.bin
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password xxx
 login
 transport input telnet
scheduler allocate 20000 1000
end
naseromer
I cannot see any  ip  in GigabitEthernet0/0
I have done further setting and posted new configuration. I am able to ping 4.2.2.2 but its not going further for internet access. any suggestion?
