Cisco Router 866VAE
assistenzapea1
Hello a my costumer buys the model in object. I tried to config but the interface vdsl don't come up. I hope because is that is the wrong model for the italian ADSL.
Is possible that is about this that i cannot use it?
5 Replies 5
Mark Malone
Here is what is supported by this router types of dsl as well in it , you need to check that your isp is using the same on their end
http://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-693249.html
Hi mark here in italy we use the ANNEX A type that is supported from the model 867VAE. My customer buy the router on amazon and when ask me what model must buy i see that is indicated ADSL and i hope that have both type on board.
I ask you if is possible convert the 866 to an 867.
Thanks for answer
Hi i have never heard of them being converted as there specifically designed for certain types as below , 887 use annex a and m , 886 uses annex b
Model
DSL Technology
Minimum Cisco IOS Software Release Requirement
Cisco 867
Asymmetric DSL 2 (ADSL2) and ADSL2+ over basic telephone service (Annex A)
12.4(22)YB3 or 15.0(1)M
Cisco 886
ADSL2/2+ over ISDN (Annex B)
Cisco 866VAE
Cisco 866VAE router with VDSL2/ADSL2+ over ISDN
15.2.(2)T or 15.1(4)M2
Cisco 867VAE
Cisco 867VAE router with VDSL2/ADSL2+ over POTS
Cisco 886VA
Multimode VDSL2 and ADSL2 and 2+ over ISDN
15.1(2)T
C886VAG
Multi-Mode VDSL2/ADSL2+ over ISDN
15.1(4)M
Cisco 887
ADSL2/2+ over POTS (Annex A)
Cisco 887M
ADSL2/2+ over POTS (Annex M)
Cisco 887V
Very-high-bit-rate DSL 2 (VDSL2) over POTS
12.4(22)YB1, 12.4(24)T, or 15.0(1)M
Cisco 887VW, Cisco 887VG, and Cisco 887VGW
VDSL2 over POTS, with 802.11n and 3G
15.0(1)M
ok i hope that my customer must return it to amazon and change with right model.
Thanks a lot for your support
No problem just mark the post correct if it has answered your query thanks
