Cisco Router 871 port Forwarding
jongbeomk
hi everyone,
I am very new to cisco router; however, i have a big challenge.
I am using server 2008 as dhcp server.
yep i got ip helper-address 192.168.1.10 to work.
but now i can't get this port forwarding working..
i am trying to use 17501 as a workstation rdp. this workstation get an ip from the server 2008
I tried so many things but still cannot get it to work.
please help me here..
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname tarvos
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret 5 $1$qP3E$Vl5lZ7rVf/lMsV8epdO8X/
no aaa new-model
resource policy
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.99
ip dhcp excluded-address 10.10.10.251 10.10.10.254
ip dhcp pool ccp-pool1
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki trustpoint TP-self-signed-3097238650
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3097238650
revocation-check none
rsakeypair TP-self-signed-3097238650
crypto pki certificate chain TP-self-signed-3097238650
certificate self-signed 01
  3082024D 308201B6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33303937 32333836 3530301E 170D3039 31323032 31363535
  35365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30393732
  33383635 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BEA4 F68CE458 55EC0D64 421E49B6 710B7A9B 6FF71317 1D64496E E2567ABC
  CC0D8DF5 16771052 E5EEF6E0 CDAA6FE3 E228A0E0 54D3F623 3766A680 B43E0DC7
  2BA5D308 5CC41522 D480F899 404AD050 AB2BB066 E6E18AD1 F9F5E040 086E15FC
  EFA2184F D4AD1BBF 24DBDA7B 3356E9DD 65A9130F 2E0CF1FC 19D4BA43 7D0598B6
  4CF70203 010001A3 75307330 0F060355 1D130101 FF040530 030101FF 30200603
  551D1104 19301782 15746172 766F732E 796F7572 646F6D61 696E2E63 6F6D301F
  0603551D 23041830 168014A9 F712F408 E808324B EC480CD5 4768EE21 35D75730
  1D060355 1D0E0416 0414A9F7 12F408E8 08324BEC 480CD547 68EE2135 D757300D
  06092A86 4886F70D 01010405 00038181 00A1FD45 067AB83C 7789EEFA 9B45930C
  135F0315 4A44A7A7 3C72DD95 0CC181B6 3B9C1741 C528CFED E87674C2 C9E4F672
  149CD09B CA4624D2 D218BDA2 42A0D02D 7D69A946 AF78678E 8BFF99BD 11B3BAAB
  A493797C 5D1EB2BD 25B807C5 2C759B84 296CFC8D 4126D10F 5F7C5C9E 19CDBFCA
  3E344E4B B3835EF1 7E28FE09 C865243D 76
  quit
username admin privilege 15 secret 5 $1$6SC2$T64uIRxP9y8.4vMg8DscX.
interface FastEthernet0
interface FastEthernet1
switchport trunk native vlan 2
switchport mode trunk
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
interface Vlan2
ip nat inside
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source list NatVlan2 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.1.51 17501 interface FastEthernet4 17501
ip access-list standard NatVlan2
remark vlan2
remark CCP_ACL Category=2
permit 192.168.1.0 0.0.0.255
ip access-list standard vlan1
remark vlan1
remark CCP_ACL Category=1
permit 10.10.10.0 0.0.0.255
ip access-list standard vlan2
remark vlan2
ip access-list extended rdp02
remark rdp02
permit tcp any eq 17501 host 192.168.1.51 eq 17501 established
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
no cdp run
control-plane
banner exec ^CC
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^CCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
webvpn context Default_context
ssl authenticate verify all
no inservice
end
johnlloyd_13
Level 9
Level 9
Try adding a static default route:
ip route 0.0.0.0 0.0.0.0 dhcp
thanks for the reply.
I will try tomorrow morning.
hm.. still i can't make it to work from out side to inside..
is there any other ides?
Configure your FE port where your PC is connected in access mode
interfacce fast x
switchport access vlan 2
switchport mode acess
Make sure you've got the Layer 2
VLAN configured
871(config)#vlan 2
Kindly post your new running config, show vlan-switch, show ip interface brief and ping results to 192.168.1.10 and 192.168.1.51 from the 871.
Also post the ipconfig and ping to 192.168.1.1 and 192.168.1.10 output from your PC.
