NAT Configuration for T1 Router
spencer.sheehan
When I plug the T1 into the serial interface on the router, I am able to ping the ISP gateway.  However, none of my LAN users can get out.  Is there something with my NAT configuration?  Any advice would be helpful.
interface FastEthernet0/0
description DATA_LAN
ip nat inside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address x.x.x.x 255.255.255.252
ip nat outside
encapsulation ppp
no ip route-cache !
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip http server
ip http secure-server
ip nat pool no-overload 192.168.1.2 192.168.1.254 prefix-length 24
ip nat inside source list 7 pool no-overload
access-list 7 permit 192.168.1.0 0.0.0.255
2 Accepted Solutions
Spencer,
Sorry...I posted another message before I saw the actual problem....Please make the change to your nat statement and you should be good.
ip nat inside source list 7 interface s0/0/0 overload
HTH,
John
HTH, John *** Please rate all useful posts ***
From the looks of it, you don't have routing enabled. Turn it on by typing "ip routing" at the (config) prompt and see if that resolves your issue.
HTH,
John
Please rate helpful posts...
7 Replies 7
John Blakley
I see an issue. Your nat pool will need to nat to a public address if you're going to use it like this. You can go out dynamically using the address that you have on the serial side by changing your translation statement:
Thank you for your reply.  Here is the output requested.
Sending 5, 100-byte ICMP Echos to x.x.x.x, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/8 ms
happy-dans-t1#ping x.x.x.x sour fa0/0
Packet sent with a source address of 192.168.1.1
Success rate is 0 percent (0/5)
happy-dans-t1#show ip nat tran
Pro Inside global      Inside local       Outside local      Outside global
icmp 192.168.1.2:10    192.168.1.1:10     x.x.x.x:10  x.x.x.x:10
--- 192.168.1.2        192.168.1.1        ---                ---
Spencer,
HTH,
John
John,
That fixed the issue that I was having.  However, now I am having an issue with my routing table not populating.  I can ping my ISP gateway from both sides, the router just won't take the routes I have.  As you can see in the above config, I clearly have my static default route set.
happy-dans-t1#show ip route
Default gateway is not set
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
t1-router#ping x.x.x.x sour fa0/0
t1-router#
HTH,
John
This seem to help everything and get this connection working.  Thanks John!!
Awesome Thanks for the ratings!
