Cisco Router 876; automatically connect / disconnect DSL
macgoo18xx
Hello ,
at first sorry for my bad english, althrough i hope you understand me.
I have a Cisco Router 876.
I want (…config !...) that my router automatically connect / disconnect to the internet (DSL), if no traffic (ca. 5 minute) is running.
I hope anyone can help me.
PS. Here is my currently Config-file:
version 12.4
no service pad
hostname xxxxxxxxxxxx
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging buffered
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock timezone Berlin 1
clock summer-time Berlin date Mar 30 2003 2:00 Oct 26 2003 3:00
dot11 syslog
no ip source-route
ip cef
ip domain lookup source-interface Dialer1
ip name-server xxxxxxxxxx
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw udp timeout 15
ip inspect name myfw tcp timeout 3600
ip inspect name myfw h323 timeout 3600
no ipv6 cef
username xxxxx privilege xx view xxxx password 0 xxxxxxx
archive
log config
  hidekeys
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
pvc 1/32
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ppp chap password xxxxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip dns server
ip dns spoofing
ip nat inside source list traffic_to_nat interface Dialer1 overload
ip nat inside source static udp 192.168.10.30 8000 interface Dialer1 8000
ip access-list standard traffic_to_nat
permit 192.168.10.0 0.0.0.255
no logging trap
access-list 102 remark SDM_ACL Category=16
access-list 102 permit ip 192.168.10.0 0.0.0.255 any
access-list 111 permit tcp any any eq telnet
access-list 111 permit icmp any any administratively-prohibited
access-list 111 permit icmp any any echo
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any packet-too-big
access-list 111 permit icmp any any time-exceeded
access-list 111 permit icmp any any traceroute
access-list 111 permit icmp any any unreachable
access-list 111 permit udp any eq bootps any eq bootpc
access-list 111 permit udp any eq bootps any eq bootps
access-list 111 permit udp any eq domain any
access-list 111 permit esp any any
access-list 111 permit udp any any eq isakmp
access-list 111 permit udp any any eq 10000
access-list 111 permit tcp any any eq 1723
access-list 111 permit tcp any any eq 139
access-list 111 permit udp any any eq netbios-ns
access-list 111 permit udp any any eq netbios-dgm
access-list 111 permit gre any any
access-list 111 deny   ip any any
access-list 122 deny   tcp any any eq telnet
access-list 122 permit ip any any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 120 0
login local
length 0
scheduler max-task-time 5000
end
paolo bevilacqua
DSL connections are meant to be permanent. Since it takse a relatively long time to re-establish a connection, it is not recommended that DSL connections are brought up and down just like that.
However if you really want to do something like that, you will need to write an EEM script, about which you can search and learn on cisco.com
Thanks Paolo for your answer .
Maybe i tested it, with the EEM script.
Nice greetings from Germany
macgoo18xx
Hello Paolo or other ,
i read your message once again. I think there is a mistake on my part.
I know that the DSL-signal permanent there, that’s OK too.
I mean, I start my browser and a connection will establish (WAN…to the internet).
Respectively I don’t use the browser or any program (..what internet used) , after 5 minute the internet connection should be closed.
I think this is a better described.
Yes, answered above already.
