Cisco router 877w + playstation 3 (dns error)
orgullovikingo
I have a problem with my ps3, when I do a test network connection, it fails in the test internet connection step, it shows 80710102 dns error.
The IP of my router is 192.168.1.1, the IP of my ps3 is 192.168.1.20. I have a laptop with 192.168.1.2. All devices are configure statically (IP, subnet mask, gateway and dns servers).
I have nat configured in my router, and I have forwarded the ports for ps3 that it needs. I've tried forward 53 port to my ps3, but it fails too.
I will put my config later, when I come to my home.
Thanks beforehand.
Cheers...
Kevin Brennan
Hi Oliver,
I assume that your laptop works correctly?
It's unlikely that your PS3 needs port 53 NATted *to* it - more likely that it needs access out to some host on port 53.
As you say, if you could post your full config, that would be very helpful
Kevin
thank you very much for your reply.
Yes, my laptop works correctly. To say too, that I can play online in my ps3, but I have to try it more of once for running a session in playstation (online zone). When I do a test network connection, it always fails with dns error. When I run a online session, when it fails, it shows dns error too.
My config:
Current configuration : 3146 bytes
version 12.4
no service pad
service password-encryption
hostname xxxgw
boot-start-marker
boot-end-marker
enable secret 5 xxx/
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization exec default local
aaa session-id common
resource policy
clock timezone GMT 0
ip subnet-zero
ip cef
no ip domain lookup
ip domain name no-ip.org
ip name-server 87.216.1.65
ip ssh authentication-retries 4
vpdn enable
username xxx privilege 15 secret 5 xxx/
interface ATM0
description xxx DSL line Phone #xxx
no ip address
no atm ilmi-keepalive
pvc 8/35
  pppoe-client dial-pool-number 1
dsl operating-mode auto
dsl enable-training-log
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxx
ppp chap password 7 xxx
ppp pap sent-username xxx password 7 xxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.2 6885 interface Dialer1 6885
ip nat inside source static tcp 192.168.1.2 6884 interface Dialer1 6884
ip nat inside source static tcp 192.168.1.2 6883 interface Dialer1 6883
ip nat inside source static tcp 192.168.1.2 6882 interface Dialer1 6882
ip nat inside source static tcp 192.168.1.2 6881 interface Dialer1 6881
ip nat inside source static tcp 192.168.1.20 80 interface Dialer1 80
ip nat inside source static tcp 192.168.1.20 443 interface Dialer1 443
ip nat inside source static tcp 192.168.1.20 5223 interface Dialer1 5223
ip nat inside source static udp 192.168.1.20 3478 interface Dialer1 3478
ip nat inside source static udp 192.168.1.20 3479 interface Dialer1 3479
ip nat inside source static udp 192.168.1.20 3658 interface Dialer1 3658
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not authorized user!^C
line con 0
exec-timeout 60 0
password 7 xxx
no modem enable
line aux 0
password 7 xxx
line vty 0 4
exec-timeout 60 0
password 7 xxx
transport input ssh
scheduler max-task-time 5000
ntp clock-period 17176193
ntp server 195.10.6.126
end
Thanks beforehand.
Cheers...
Hi Oliver,
Your config looks okay. Could there be any more ports that you need to forward to your PS3 device?
It might be an idea to search for the root cause of that specific PS3 error message. (I've never seen a PS3!)
Kevin
Thank you very much.
No, the PS3 doesn't need more port forwarded. I've been searching for 80710102 message error, and many people fix it changing dns servers to open dns. I will change it in my router and ps3 config.
Thank you!
