Cisco Router and Unmangaged Switch (Internet Access)
GregH.NY
Hello. I have a home test environment that I would like to see if I can get internet access.
I am using a Cisco 2901 Router and an unmanaged Netgear switch.
I would like to see if I can get internet access to the device connected to the unmanaged switch.
I know I get internet access on the Router so that side is done.
I need to configure the Router to let the devices use it as a gateway.
The thing is I am having trouble with this because it will not let me configure VLAN1, IP address Subnetmask.
Any thoughts?
2 Accepted Solutions
below is a sample configuration for a 2901. You don't use Vlan 1, but one of the physical interfaces to connect the unmanaged switch:
no service pad
hostname 2901
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
archive
log config
hidekeys
interface GigabitEthernet0/0
description LAN (Netgear)
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1
description WAN
ip address x.x.x.x y.y.y.y
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 3
login
exception data-corruption buffer truncate
scheduler allocate 20000 1000
end
Lets start with basic config before move to advanced level
I have modifiled the config :
ip address dhcp client-id GigabitEthernet0/0
ip directed-broadcast 1
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1    <<<--- This port you will connect your HUB
no switchport
ip nat inside
duplex auto
speed auto
ip nat inside source list 1 interface GigabitEthernet0/0 overload
Connect one of the PC to your unmanaged switch port
configured IP address 192.168.1.2 mask 255.255.255.0 and gateway 192.168.1.1
DNS 8.8.8.8
Test
1. From PC you should able to ping 192.168.1.1
2. check you able to ping 8.8.8.8
3. browse interface google.com
BB
7 Replies 7
balaji.bandi
yes possible :
PC---Umanaged Switch---Router( where you do NAT here) --Internet
you can post current config or give us your Public IP / Priate IP - we try provide working config to test.
BB
Thanks for the help BB!
Also I do get an IP from the ISP and I can ping internet IP addresses. I just cant ping any private IP addresses on my LAN
Edit to Add: Please ask if any other info is needed.
ip access-group OUTSIDE-IN in
ip nat outside
no ip virtual-reassembly
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip access-list extended OUTSIDE-IN
deny tcp any any eq telnet
permit ip any any
ip nat outside
duplex auto
speed auto
no switchport
ip nat inside
duplex auto
speed auto
DNS 8.8.8.8
Test
BB
Thanks BB that worked!
Thanks for the sample config Georg Pauwen! This answered my next challenge (LAN DHCP) after I got the internet traffic resolved.
Devices connected to Netgear all have internet access.
The onboard Gigabit ports are routed ports by default, so the'no switchport' command is not necessary, I don't even think you can convert them to layer 2 ports ?
You also need the default route, preferably pointing to the next hop IP address, but since the address is acquired through DHCP, it should be:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
@Georg Pauwen  good one...by typing we always think we are in switch port...hahhah ..so it come as typo. end the command has no meaning router. (a s you said until some one made switch port.)
BB
no service pad
hostname 2901
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool LAN
archive
log config
hidekeys
ip nat inside
duplex auto
speed auto
description WAN
ip nat outside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
line con 0
line aux 0
line vty 0 3
login
end
