Cisco router can connect to internet but any connected devices can't
Karakas
I configured my cisco router to connect to the internet and it does connect but any connected devices don't have internet. My router is a cisco 897VA-VAB something and here is my configuration I suspect it has to do something with the vlan:
Using 4528 out of 262136 bytes
! Last configuration change at 07:58:52 UTC Sun Nov 3 2024 by karakas
version 15.4
hostname karakas
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.1.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.128
default-router 10.10.10.1
lease 0 2
ip dhcp pool 192.168.1.0 255.255.255.0
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 4.2.2.2
no ip domain lookup
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip name-server 4.2.2.2
ip cef
no ipv6 cef
cts logging verbose
license udi pid C897VAB-K9 sn FCZ2229E352
vtp version 2
username karakas privilege 15 secret 5 $1$/iTv$MydhEFx5bow43C/pA2gbN1
controller VDSL 0
no cdp run
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address 192.168.2.2 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
description $ETH_LAN$
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Vlan1 overload
ip route 0.0.0.0 0.0.0.0 192.168.2.1
ip route 0.0.0.0 0.0.0.0 Vlan1
tftp-server flash:/firmware/vdsl_bond.bin
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner exec ^C
% Password expiration warning.
2 Accepted Solutions
balaji.bandi
Try below and device in the Lan able to get Interenet.
no ip nat inside source list 1 interface Vlan1 overload
no ip route 0.0.0.0 0.0.0.0 Vlan1
ip routing (some device have default enable in case required add)
ip nat inside source list 1 interface GigabitEthernet8 overload
This was not sure, using Lan PC you trying to connect to remote vpn server using any connect ?
before connecting make sure you have internet connection to PC - so lets fix that before you proceed further.
still issue post below output
show run
show ip interface brief
show ip route
what is the PC IP you get ?
from PC post ipconfig /all and ping 8.8.8.8 and google.com
BB
@Karakas
 This route is not necessary
And you NAT is incorrect
Change to this
balaji.bandi
show run
show ip route
BB
Brother I have internet thank you very much
@Karakas
Change to this
Thank you very much as well
